boot with cd, start installation.
on install screen after copying required files u will see option to boot inst recovery console.
start recovery console u will need ur administrator account's password to continue.
then u will boot into command mode knows as recovery console.
type help for more info and available command.
that is the only option to recovery.
1 aadi + 1 aadi = 1 full ;)
Even if u reinstall th whole OS, u will NOT lose any of ur programs or data, bacause only th OS files are re-installed and th disk is NOT formatted. I tried it myself a lot of times in XP, and it always solved my problem.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
my frnd if u re-install the entire os wont the registry entrie be lost rendering all ur programs useless, be4 doing re-install tell him to take a backup of his registry
Attack life, it\'s going to kill you anyway.
Reinstalling windows does not make much change regarding
registry entries by programs installed after the last time setup ran.
However some modified keys might be reset to their defaults.
Not much to worry about not being able to use some programms .
However backin up the registry does not hurt.
