Old 22-10-2008, 12:55 PM   #1 (permalink)
Tech'ing life seriously!!
sude's Avatar
Exclamation How to take screenshots in DOS mode? Please help!!
dear forum users..
being a student of BCA, i have project to complete using C/C++. But i am stuck with a vital problem..
i need a tool which would enable me to take screenshots of the projects in DOS mode.
how would i do it...
please help me out.
i checked the net and also tried several softs but to no avail..
hoping of quick replies.
thnx in advance,
regrds, SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 22-10-2008, 01:27 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: How to take screenshots in DOS mode? Please help!!
Is the entire screen in DOS mode or jus a window opened as a DOS mode ?? (like say command prompt window) ?
Neways... hv u tried the Printscreen option or Alt+printscreen combo for the same ??
a few options.
1.) 2 possibilities:
A. Run in a DOS window, then use the Print Screen! i.e
You must have the DOS (or say a C/C++ user screen) in "windowed" rather than full-screen mode (hit ALT-Enter to switch back and forth b/w windowed and full screen mode).
Then hit the PrintScreen key, and open a program like Paint, then click Edit => Paste to paste the screenshot.
B. Download a DOS screen grabber utility, e.g. from here:
http://www.3dgamers.com/utils/
alternatively,
2.) Irfanview has a Hotkey function, which can save a captured image as any file type you can imagine, at your command, or at pre-determined intervals.
now,
3.) if your using DOSBox, you can press CTRL-F5 to save a screenshot.
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Last edited by ashu888ashu888; 22-10-2008 at 01:36 PM. Reason: Automerged Doublepost
ashu888ashu888 is offline
Old 22-10-2008, 02:13 PM   #3 (permalink)
paroh's Avatar
As dosbox always work for me
paroh is offline
Old 22-10-2008, 04:14 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Best technique, click the pic wid a digicam, foolproof(worked for me lolz)
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 22-10-2008, 04:22 PM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Run it in windows, installed in a virtual machine, and take screenshots in the host OS. Thats what I always do for dos programs.
dheeraj_kumar is offline
Old 22-10-2008, 05:56 PM   #6 (permalink)
AFK
thewisecrab's Avatar
Run it under a window on your Vista/XP and press Ctrl+PrintScreen to capture a screen shot. Paste that in Paint/GIMP etc. and save it
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 22-10-2008, 06:09 PM   #7 (permalink)
^^ Easier, yes. But you cant get shots of BGI graphics that way.
Old 22-10-2008, 08:09 PM   #8 (permalink)
paroh's Avatar
with dosbox emulator u can take BGI graphics also
paroh is offline
Old 23-10-2008, 12:29 AM   #9 (permalink)
Already posted the many ways available at the user's disposal in the 1st post..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 04-11-2008, 10:20 PM   #10 (permalink)
Trying to find my feet...
I am a Final Yr student B.tech IT. gone through the same problems.
i used a software called screen theif for my egavga.bgi assignments. contact me if you dont find anything else. I ll mail it to you.
antz.bin is offline
PIO mode instead of UDMA mode 2 !!! PLS. HELP ME !!! rachitboom2 QnA (read only) 7 19-08-2007 10:11 PM
screenshots magneticme200 Software Q&A 8 25-07-2007 11:34 PM
Difference Between FF Ordinary Mode & FF Safe Mode rajas700 QnA (read only) 9 27-08-2005 02:38 PM
NFS UG2 CAR SCREENSHOTS Prajith Gamerz 1 06-07-2005 01:19 AM
what is standby mode and hibernate mode.. thegame_rulez QnA (read only) 1 16-03-2005 11:46 AM
- by gforz
- by soumya
