Old 20-10-2008, 03:46 PM   #1 (permalink)
din
Tribal Boy
din's Avatar
Default Please suggest a good folder synchronize utility
Please suggest a good folder synchronize utility (OS - Win XP)
Basically syncing files between a PC and a laptop through wireless networking. There are a huge number of files (like greater than 90,000 files mainly consists of html files, php files and images). So copying the files always is not a good idea.
Looking for something that have an option like an auto sync (copy only those files which are changed), planning to set it daily / once in three days.
Thanks in advance.
Forgot to add - file paths will be greater than 255 characters in many cases (Hint : Can't use programs like DeltaCopy)
din is offline
Old 20-10-2008, 06:16 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Please suggest a good folder synchronize utility
You can use Syncback freeware from here
http://www.2brightsparks.com/syncback/syncback-hub.html
See the box in the bottom right hand corner of that page
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 21-10-2008, 07:50 PM   #3 (permalink)
swatkat's Avatar
Microsoft SyncToy
http://www.microsoft.com/downloads/d...DisplayLang=en
http://swatrant.blogspot.com/
swatkat is offline
Old 21-10-2008, 08:01 PM   #4 (permalink)
din
Tribal Boy
din's Avatar
Thank you, I will check both soon.
din is offline
Plz response.. for good Defragmenting utility Sathish Software Q&A 7 20-08-2008 07:36 AM
suggest a good tv tuner card with good recording capability NiluGeek Hardware Q&A 1 06-10-2007 08:28 PM
Please Suggest A Good Linux\Windows File Backup & Syncing Utility unni Open Source 3 01-10-2007 10:17 PM
good compression utility.......... alaap_anujan Gamerz 3 20-11-2005 12:53 AM
- by gforz
- by soumya
