Old 20-10-2008, 09:58 AM   #1 (permalink)
Exclamation Tell me the difference...
Have you ever used the IC's CM8870 and MT8870 in any of your projects? Then, can anybody tell me the differences between those as far as the applications are concerned?Can I replace the one with the other???
madhusoodan is offline
Old 20-10-2008, 03:58 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Tell me the difference...
Both are compatible as per http://www.8051projects.info/forum/t...44&whichpage=4
There should be no change in pin layout, but check the datasheets for confirmation.
dheeraj_kumar is offline
Old 20-10-2008, 05:19 PM   #3 (permalink)
Thank you! There's no difference between the two as per the data sheets. But CM8870 didn't work in my case, where I had to use MT8870, but I couldn't get that IC
VB & VS Difference? iMav Programming 7 06-09-2008 11:27 AM
Difference between what mrmani Tutorials 2 12-10-2006 05:30 PM
what is difference between vb and vb.net arunks QnA (read only) 3 12-10-2006 12:35 PM
Difference Between DVI & D-Sub tiblu Hardware Q&A 2 31-05-2006 01:46 AM
What is the Difference b/w these RAM... dabster Hardware Q&A 4 28-04-2006 05:24 PM
- by gforz
- by soumya
