Old 17-10-2008, 12:23 PM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default fryrender plugin
hi ...
i downloaded a demo version fryrender for 3ds max the plugin.
i created simple scene with fry camera and its textures a sphere and shadow on a plane ,, vray takes 1sec but fryrender took 20min but there was much noise..
pl. explane this.. is there some different method or the core needs to be configured????
arpanmukherjee1 is offline
Old 17-10-2008, 06:12 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: fryrender plugin
You need to configure it, obviously. All plugins work to their full potential only if you specify your requirements. Configure it properly.
dheeraj_kumar is offline
Old 18-10-2008, 12:01 PM   #3 (permalink)
XLr8
can you pl. tell the optimum settings for a basic scene
screenshots can be really help full if you can send some
Old 18-10-2008, 06:14 PM   #4 (permalink)
I cant help you, I dont have the plugin, and I've uninstalled 3DS.
Skype Plugin boosters QnA (read only) 1 02-09-2007 03:36 AM
Which Plugin to install???? sridatta QnA (read only) 4 15-03-2007 10:42 PM
REQ: JSP Plugin for Eclipse lywyre Open Source 2 21-11-2006 03:04 PM
PLugin MP3 champ_rock Open Source 11 18-10-2005 10:07 PM
WHICH IS THE BEST A/V EFFECT PLUGIN FOR WMP 9 kl_ravi QnA (read only) 11 10-04-2004 01:20 AM
- by gforz
- by soumya
