Old 13-10-2008, 09:49 PM   #1 (permalink)
Question jdbc connection with oracle
hi folks i want to connect java application program with oracle 10g express edition . i tried hell lot of times but it showing classnotfound exception.i dont know which driver to use whether oci or thin driver.i also set classpath for oracle14.jar in environment varibles.i dont know wats the problem. can any of u help me regarding this.pls reply asap.thankx in advance folks.plssssssssssssssssssssssssssssss.....
vijay_ss2004 is offline
Old 14-10-2008, 11:12 AM   #2 (permalink)
ruturaj3's Avatar
Default Re: jdbc connection with oracle
Post ur program. May be some thing wrong with ur coding.
chk this
http://www.java-tips.org/other-api-t...ng-jdbc-4.html
ruturaj3 is offline
Old 16-10-2008, 06:44 AM   #3 (permalink)
Red face Re: jdbc connection with oracle
yeah this was my code can u find wats thw error is
import java.sql.Connection;
import java.sql.ResultSet;
import java.sql.Statement;
import java.sql.DriverManager.*;
import java.sql.*;
public class simple
public static void main(String args[]) throws SQLException,ClassNotFoundException
try
//DriverManager.registerDriver(new oracle.jdbc.OracleDriver());
Class.forName("oracle.jdbc.driver.OracleDriver");
Connection con=DriverManager.getConnection("jdbcracleci:@ XE","system","vijay");
Statement st=con.createStatement();
ResultSet rs=st.executeQuery("select * from sample");
while(rs.next())
System.out.println(rs.getString(1));
System.out.println(rs.getInt(2));
con.close();
catch(SQLException e)
System.out.println(e.getMessage());
pls suggest me wat to do ....................thankx in advance ....
after executing the above program i m getting
C:\Program Files\Java\jdk1.5.0\bin>java -classpath . simple
Exception in thread "main" java.lang.ClassNotFoundException: oracle.jdbc.driver.
OracleDriver
at java.net.URLClassLoader$1.run(URLClassLoader.java: 200)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.j ava:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:3 06)
at sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:268)
at java.lang.ClassLoader.loadClass(ClassLoader.java:2 51)
at java.lang.ClassLoader.loadClassInternal(ClassLoade r.java:319)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:164)
at simple.main(simple.java:15)
pls help folks...................
Last edited by vijay_ss2004; 16-10-2008 at 08:05 AM. Reason: Automerged Doublepost
Old 16-10-2008, 03:05 PM   #4 (permalink)
Why are you specifying the classpath when compiling the source?
Make it as your environment variable and make sure that your classes12.zip (or whatever) is in your classpath.
Bandu is offline
Old 16-10-2008, 03:41 PM   #5 (permalink)
Excessive happiness
furious_gamer's Avatar
ClassNotFoundException insense means that the compiler was unable to find the Oracle Driver file....Make sure u copy that file and paste it in ur classpath...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Oracle Unveils Oracle(r) Virtual Machine Garbage Technology News 2 15-11-2007 06:58 PM
Want a basic mobile and connection for net connection Chetan1991 Mobiles and Tablets 5 31-10-2007 11:13 AM
Oracle Versions and Supported OSs etc., about Oracle sravan_mdo Software Q&A 1 27-08-2006 05:59 PM
Learn :: USING JDBC(with ACCESS), AWT, & SWING in JAVA(JDK 1.5) imdbest Tutorials 1 11-07-2006 11:47 AM
JDBC saro_gn QnA (read only) 1 27-04-2006 02:36 PM
- by gforz
- by soumya
