Old 25-09-2008, 04:00 PM   #1 (permalink)
pavilion's Avatar
Default CopyFromScreen method isn't affected by clipping region , why ??
I want to copy a portion of desktop screen and draw it on form (that portion can be in rectangular , elliptic or freeform shape ) , so I have to use a clipping region because the method just copy a rectangle portion from screen . Sound easy , I hope you understand
First I used APIs : SelectClipRgn and BitBlt , everything's done perfectly . Then I tried to make it in .NET way , use CopyFromScreen method and Graphics.SetClip . But it appear that the CopyFromScreen method isn't affected by clipping region . For example
 Graphics w = this.CreateGraphics;
w.SetClip(new Rectangle(0, 0, 100, 100);
w.CopyFromScreen(0, 0, 0, 0, new Size(500, 500));
You see, I copy a 500x500 rectangle from screen into a 100x100 clipping region , but the form still draw the 500x500 rectange ???
pavilion is offline
Old 05-10-2008, 07:10 PM   #2 (permalink)
swatkat's Avatar
Default Re: CopyFromScreen method isn't affected by clipping region , why ??
I don't know anything related to .NET. But, Google lead me to this
http://www.dotnetcurry.com/ShowArtic...ookieSupport=1
Hope that helps....
http://swatrant.blogspot.com/
swatkat is offline
Old 18-10-2008, 09:34 AM   #3 (permalink)
pavilion's Avatar
Thanks ^^ but it's not exactly my situation , the tutorial in that link doesn't use clipping region
pavilion is offline
Stage6 was Hacked-All online movie site affected gopi_vbboy Chit-Chat 2 28-02-2008 08:54 AM
W810i Virus Affected dareprasanna Mobiles and Tablets 2 22-12-2007 12:06 AM
Affected by BackDoor.SdBot2.RMI redhat Software Q&A 10 30-03-2007 10:32 AM
is my pc affected by a virus??? abhishek_sharma Software Q&A 4 31-03-2006 09:28 AM
Is there a Correct method /way of using an ups? john_the_ultimate QnA (read only) 8 21-06-2005 10:29 PM
- by soumya
