Old 12-09-2008, 12:14 PM   #1 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Linux Shell Scripting - bash: ELF command not found
Hello.!
I have a executable tbc stored at $HOME/abc/xyz/tbc.Now, if I try running the executable with ". $HOME/abc/xyz/tbc" or "source $HOME/abc/xyz/tbc", it gives a message:
bash: ELF : command not found
But if I first cd to $HOME/abc/xyz and then run"./tbc", it works just fine.
What's the issue here.?
Thanks.!
Life is as complicated as you say it is.
shady_inc is offline
Old 12-09-2008, 02:47 PM   #2 (permalink)
18 Till I Die............
Default Re: Linux Shell Scripting - bash: ELF command not found
Works fine for me. Can you show us your script?
http://www.bash.org/?258908
mehulved is offline
Old 12-09-2008, 08:05 PM   #3 (permalink)
shady_inc's Avatar
The executable I am talking about is the Befunge Compiler.It can be found here.I compiled the C source file and am trying to the executable when it comes up with the error.
Old 12-09-2008, 08:24 PM   #4 (permalink)
I see right through you.
Sykora's Avatar
When you use source, you're asking the shell to interpret the file. When you try to source a binary executable, it'll try to interpret it and fail. Use source only on scripts which the shell can understand.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 12-09-2008, 09:27 PM   #5 (permalink)
shady_inc's Avatar
But that doesn't explain why the executable works when I cd to it's directory and then source it.
Old 13-09-2008, 01:35 AM   #6 (permalink)
This is definitely wrong, no wonder it's giving you a problem. It can be $HOME/abc/xyz/tbc but not this.
Here's the description of source from the man pages
source - Evaluate a file or resource as a Tcl script
definitely not what you want.
Thanks.!
Cos you're running the executable file itself out here.
mehulved is offline
Good Book on Shell Scripting? paragkalra Open Source 2 07-07-2007 08:05 PM
Which book to refer.... learning linux bash scripting.. aditya.shevade Open Source 4 07-03-2007 08:17 AM
goto command for shell scripting? paragkalra Open Source 1 24-07-2006 10:33 AM
Learn the Linux Command Line and Shell Scripting thunderbird.117 Open Source 5 05-07-2006 11:42 AM
HELP shell scripting!! mediator Open Source 3 13-08-2005 12:33 AM
- by soumya
