Old 11-09-2008, 09:54 AM   #1 (permalink)
Exclamation Connection to mySQL through PHP
Dear Digiterzz!!
I'm trying to create a connection between mySQL database through PHP but I'm not able to do so..
Check out the following code:
<?php
$dbhost = 'mysql2.freehostia.com';
$dbuser = 'db_User';
$dbpass = 'admin';
$conn = mysql_connect($dbhost, $dbuser, $dbpass) or die('Error connecting to mysql');
$dbname = 'db_Rakshak';
mysql_select_db($dbname);
Please help!!
Thanks
Thanks and Regards,
Prathamesh R. Tawde
prathamtawde is offline
Old 11-09-2008, 02:51 PM   #2 (permalink)
Default Re: Connection to mySQL through PHP
Originally Posted by vikas12345 View Post
please post the error msg you are getting while connecting mysql to php
blank web page appears..
Not Found
The requested URL /test.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.33 Server at prathamtawde.freehostia.com Port 80
Thanks and Regards,
Prathamesh R. Tawde
Last edited by prathamtawde; 11-09-2008 at 02:57 PM. Reason: Automerged Doublepost
Old 11-09-2008, 03:49 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
If a 404 error, then it's not your code problem. Check the path of file and put the address according to that.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 11-09-2008, 05:57 PM   #4 (permalink)
Addicted to FOSS
ManishSinha's Avatar
You are trying to run this code on your system locally or on the freehostia's hosting service?
ManishSinha is offline
Old 11-09-2008, 07:22 PM   #5 (permalink)
18 Till I Die............
What is more recommended to use - mysql_connect or pear mdb2? And why?
http://www.bash.org/?258908
mehulved is offline
Old 11-09-2008, 07:40 PM   #6 (permalink)
Addicted to FOSS
I personally prefer mysql_connect
pear mbd2 may be your choice...
Mysql Help Desi-Tek.com Open Source 4 27-11-2006 12:24 PM
help in PHP-mysql bukaida Open Source 7 08-11-2006 03:20 PM
php and mysql arunks QnA (read only) 3 12-08-2006 07:58 PM
connection of PHP & MySQL Trinity QnA (read only) 9 24-07-2005 11:47 AM
MySql Administrator , connection prob ! help Butterfly QnA (read only) 1 07-10-2004 08:30 PM
- by soumya
