Old 29-08-2008, 09:43 PM   #1 (permalink)
AFK
thewisecrab's Avatar
Default Been enrolled in Web designing contest, need help
As the title reads
I've been enrolled in a web designing contest (being the most computer-centric person among the class)
The rules are:
1)Make a site using any FOSS or Script it on your own (CSS.XHTML,etc)
Topic will be given on the spot
2)Upload it onto a free web host with domain
3)Should be functional in 4 hours
Now the problem is:
1) I know basic HTML, nothing else. What more should i learn?
( The contest is in 20 days)
2) Does Wordpress fit the bill?
I'm banking on Q1 as the FOSS that I found are relatively weak (Kompozer,Scribus,etc)
Also, WP being a heavy internet based app will be handicapped in the dialup internet they'll be providing
What should I do?
I know the timeframe is small, but any help would be appreciated
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 29-08-2008, 09:56 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Been enrolled in Web designing contest, need help
Wordpress won't be heavy for dialup if you optimize it. You can easily have a static page as your home page and some another page for posts. Also, instead of showing 10 posts per page, you can reduce it to 1 so that pages will load faster when compared.
Ofcourse WP has fabulous themes! So go ahead with wordpress
Also, since they have given you the option to write the scripts on your own, if you know PHP-MySQL, XHTML and CSS, you can write a basic engine in 2 days! I think they will prefer hand made scripts instead of ready made.
Also give some info about your competition. How e-literate they are?
गीक होना माँगता
victor_rambo is offline
Old 29-08-2008, 11:24 PM   #3 (permalink)
AFK
Not much from what I can fathom (and by what my seniors tell me)
But they can make out ready-made from hand written
Also the circular categorically states that NO paid software can be used
This rules out Publisher and Dreamweaver.
Also, the site (the pages including the home page with images) should NOT excede 4 mb
This means the scripts cannot be more than 4 mb ikn size, not the size of the site on the host.
I'm keen to use WP, but I think it'll be pretty slow to customize on dial-up
So I'm looking for any language help possible
(WP workarounds,if any, are appreciated )
Old 29-08-2008, 11:42 PM   #4 (permalink)
हॉर्न ओके प्लीज़
ok,so u mean that individual scripts cannot be graeter than 4 MB? but all scripts taken together can be greater than 4 MB?
गीक होना माँगता
Old 29-08-2008, 11:43 PM   #5 (permalink)
AFK
no no
the site folder containing all site scripts and images should not exceed 4mb
is it too little?
and
i do know basic html
what other langs can i learn in 15 days?
Old 29-08-2008, 11:52 PM   #6 (permalink)
हॉर्न ओके प्लीज़
4 MB is too little for wordpress
Also, have they allowed you to use databases?
गीक होना माँगता
Last edited by victor_rambo; 29-08-2008 at 11:54 PM. Reason: Automerged Doublepost
Old 30-08-2008, 08:23 AM   #7 (permalink)
AFK
I have no idea about that (databases on websites, I heard this for the first time)
Forget wordpress then
What languages should I learn in the next 15 days?
CSS, XHTML, etc.?
which one should I learn for making really good and presentable websites?
Again I'm saying that I have knowledge of HTML
Old 30-08-2008, 09:12 PM   #8 (permalink)
हॉर्न ओके प्लीज़
Learn XHTML markup(HTML with minor modifications and defined standards, easy since u know HTML)and CSS.
Then download a open source template from http://www.oswd.org and modify it
गीक होना माँगता
Old 30-08-2008, 10:19 PM   #9 (permalink)
AFK
Got it
Should w3 consortium do the trick for XHTML, CSS?
And will i be able to finish the language on time????
(difficult to answer, I know, but an estimate would help )
Old 30-08-2008, 10:39 PM   #10 (permalink)
हॉर्न ओके प्लीज़
As you said you know HTML, learning XHTML will be a piece of cake for you. Don' spend more than 15-30 mins on learning rules of XHTML. There are very few btw! And do get your code validated.
For CSS, even thats easy if you how to use the 'style' attribute in HTML.
Eg:
<div id="my_div" style="font-family: Verdana; font-size: 11px; font-weight: bold; padding: 5px; border: 2px dotted #00FF00;">
Hello World!
</div>
In CSS, you create a 'link' element in the HEAD and point it to your .css file. The CSS file simply contains the re-written code as
#my_div{
font-size: 11px;
font-weight: bold;
padding: 5px;
/*there is a shorthand technique too but first get it the long way*/
गीक होना माँगता
Old 30-08-2008, 10:42 PM   #11 (permalink)
AFK
OK
Thanks man
Any other suggestions are welcomed
I'll keep posting here if I encounter any roadblocks
Old 05-09-2008, 07:31 PM   #12 (permalink)
AFK
Q1) Does the How can I define the image in background? I mean, should the image that I want to use be in root folder or should I specify the entire directory of the picture?
Q2) Is it preferable better to have one ".css" file and then link all the heads to it?
Q3) There are some commands that W3C says that it wont work in IE. How to workaround this?
Old 06-09-2008, 03:22 AM   #13 (permalink)
18 Till I Die............
You can use absolute path or relative, IMO relative is preferred so that it doesn't break while moving project from one place to another.
Yeah, it's a good idea to have a common css file site-wide so as to give a consistent look and feel.
First make your code standards complaint then add exceptions to fix it in IE.
I am not an expert in web desinging, but my answers are based on what I have observed while fiddling around with some templates obtained from the web and customising them.
http://www.bash.org/?258908
mehulved is offline
Old 06-09-2008, 04:04 PM   #14 (permalink)
AFK
OK Thanks Man
Web Designing!! digster QnA (read only) 14 21-07-2008 11:52 PM
Web Designing nareshwithu QnA (read only) 6 30-06-2007 09:39 AM
Web Designing shashank_digitreader Tutorials 5 06-10-2006 01:08 AM
3D , @D and Web Designing akshayt Tutorials 1 17-01-2006 09:04 PM
Web Designing ravishankar QnA (read only) 11 20-01-2005 11:34 PM
