Old 18-08-2008, 05:02 PM   #1 (permalink)
Default Help with series in C++
Can anyone help me with these in C++?
The program is supposed to display solution for series for a given value of n and x. There are two series
1. x - x^3/3! + x^5/5! - x^7/7! + x^9/9! ...... till x^(2n+1)/(2n+1)!
2. 1 - x + x^2/2 - x^3/3 + x^4/4 - x^5/5 ....... till x^n/n
Thanks in advance.
hitman050 is offline
Old 18-08-2008, 05:18 PM   #2 (permalink)
18 Till I Die............
Default Re: Help with series in C++
Aren't they limits of sin x and e^(-x)
http://www.bash.org/?258908
mehulved is offline
Old 18-08-2008, 05:36 PM   #3 (permalink)
No idea about that. But I need to know how to display the series for n.
Old 18-08-2008, 07:54 PM   #4 (permalink)
Mad and Furious
redhat's Avatar
i dont know C++, but I can give u the logic behind the code...
after input of values of x and n,
set flag=1
run a loop where the counter is initialised to 1 and incremented by 2 upto (2n+1)
if flag = 1
s=s+((X^counter)/factorial of counter)
flag = 0
else
s=s-((X^counter)/factorial of counter)
flag=1
(where factorial of counter is calculated in another part and called using messages)
2nd series:
same logic as above, but initialise counter at 0, and upto n
ican give u the complete code in JAVA if u wish, but i dont know C++
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 18-08-2008, 08:07 PM   #5 (permalink)
ashfame's Avatar
#include<iostream.h>
#include<conio.h>
void main()
{ clrscr();
int x,n,sum=0,flag=0;
cout<<"Enter x,n"<<endl;
cin>>x>>n;
for(int i=0;i<n;i=i+1)
	if(!flag)
		sum=sum+(x^(2n+1))/factorial(2n+1);
                flag=1;
	else
             	sum=sum-(x^(2n+1))/factorial(2n+1);
                flag=0;
cout<<"Sum is "<<sum;
getch();
also make a function factorial(int) that will calculate the factorial of argument and return it. Similarly use it to calculate the sum of 2nd series.
P.S. - I don't have any compiler with me. Understand the logic and try yourself
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 18-08-2008, 08:13 PM   #6 (permalink)
I haven't been taught functions yet. Any other way around the factorial part?
Old 18-08-2008, 08:33 PM   #7 (permalink)
You want to create 2 for loops, one nested inside the other.
Try it, should work.
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 18-08-2008, 08:36 PM   #8 (permalink)
ashfame's Avatar
Function is used because we want to calculate factorial in every iteration. It can be done without function too.
Just use a variable to calculate factorial before calculation sum.
like
fact= <calculate using value of i>
sum=sum+.../fact;
I hope I am clear
ashfame is offline
Old 18-08-2008, 08:39 PM   #9 (permalink)
I will try it.
I am not aware of logical operator '!'. What does it do?
Old 18-08-2008, 08:48 PM   #10 (permalink)
@hitman: You might have to first go through the functions part. That comes first when learning modular languages. Will make your life easier. Ofcourse, there is a way around it for the time being.
Original code:
if(!flag)
New code that does not use factorial:
int fact, base = 0;
if(!flag)
	fact = 1;
	base = 2*n + 1;
	while(base >= 2)
		fact = fact * base - 1;
		base = base - 1;
	sum=sum+(x^(2n+1))/fact;
do the same for the else part. And remember that your sum should be a float and not an int.
I do not have C++ compiler myself.
Bandu is offline
Old 18-08-2008, 08:49 PM   #11 (permalink)
ashfame's Avatar
I will try it.
It just inverts the operand.
0 -> 1
1 -> 0
ashfame is offline
Old 18-08-2008, 08:50 PM   #12 (permalink)
Can you please explain (!flag)?
Old 18-08-2008, 08:50 PM   #13 (permalink)
ashfame's Avatar
Yeps! It should be float else decimal part will be lost everytime and sum will be less than what it should be.
if flag=0 then !flag=1
we are just using flag to keep check on the thing that series is like, you add one term and then subtract the next term and then add the next term and so on.
I forgot to change the value of flag. Sry for that. Will edit it right away.
ashfame is offline
Old 18-08-2008, 08:59 PM   #14 (permalink)
If your question is about operator !
! is a unary operator - meaning takes only one operand and takes a boolean operand always (atleast in Java. I forgot about C++ and I forgot whether C++ has boolean as a datatype or does it use 0 and 1)
Ex: x is a boolean variable.
x = true;
cout>>x; // Will output true
cout >> !x; // Will output false
Now, don't ask us whats unary and whats boolean. If those are your doubts then you might want to log off and get back to Chapter 1 in your books.
If your question is about (!flag), then the author meant if(flag == false)
if(!flag) is just a short for if(flag == false)
Again, depending on the programming language, you might have to replace false with 0 and true with 1 in above snippets.
Bandu is offline
Old 02-10-2008, 10:49 PM   #15 (permalink)
sin x = x - x^3/3! + x^5/5! - x^7/7! + ...<------- nice topic on C++
been looking for this code but i need ..any one convert this to JAVA....
been Using Jcreator now.. just past by solving perfect number ..this my problem now
in code this to JAVA
Count0paw is offline
Nokia Xpress Music Series Vs. SE Walkman Series just4fun Mobiles and Tablets 29 12-09-2007 10:50 PM
nokia n series vs sony ericsson w series... ssk_the_gr8 Mobiles and Tablets 23 11-09-2007 09:30 PM
whats the difference b/w K series and W series ? saurabh kakkar Mobiles and Tablets 1 29-07-2007 09:32 PM
Series 60 v2 vs Series 60 v3 skirix Mobiles and Tablets 5 29-06-2007 11:32 AM
ati 9800 series vs ati x1600 series vish786 Hardware Q&A 5 18-12-2006 12:48 AM
