Originally Posted by arian29
can someone please help me with the code below, i am getting error "Expected )"
con.Provider = ("Microsoft.Jet.OLEDB.4.0;data source = " & App.Path & "\" & "vbox.mdb";Jet OLEDB  atabase Password=qw34;Persist Security Info=False")
Is it
VB 6 or
VB.NET? I dont see any problem in the code.
If its
VB.NET then you cannot assign the the Provider property as its readonly. Try like this
Dim ConnectionString As String = String.Empty
Dim WorkingDirectory As String = String.Empty
Dim DataBaseFile As String = String.Empty
WorkingDirectory = System.Environment.CurrentDirectory & "\"
DataBaseFile = WorkingDirectory & "\" & "vbox.mdb"
ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & DataBaseFile & ";User ID=;Jet OLEDB:Database Password=qw34;"
Dim Con as New OleDBConnection ( ConnectionString )
If its
VB 6 then try like this.
Dim ConnectionString As String = ""
Dim WorkingDirectory As String = ""
Dim DataBaseFile As String = ""
Dim Con As ADODB.Connection
WorkingDirectory = App.Path & "\"
DataBaseFile = WorkingDirectory & "vbox.mdb"
ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & DataBaseFile & ";User Id=admin;Password=qw34;"
Set Con = New ADODB.Connection
Con.Open ConnectionString
