Old 15-08-2008, 09:08 PM   #1 (permalink)
Default C++ Adding, then loop operation
I am very new to programming and I am trying to create an application that will add 1 to 0000000000000000000, once it has added one and creates 0000000000000000001, then if i run the function again it will make 0000000000000000001 equal 0000000000000000002.
Any help would be greatly appreciated
ShArP is offline
Old 16-08-2008, 02:02 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: C++ Adding, then loop operation
0000000000000000000 is no different from 0 (assuming you're just processing them as numbers, not strings)
int num = 0;
void function()
  num = num + 1;
dheeraj_kumar is offline
Old 16-08-2008, 12:59 PM   #3 (permalink)
L0rd_Aryan's Avatar
are you talking about displaying it in a number of zeros ???
L0rd_Aryan is offline
Java-Swing buttons - adding as array in loop problem ilugd Programming 6 14-07-2008 10:06 AM
The Loop Kingdom abhi.eternal Chit-Chat 1 22-12-2007 07:13 PM
Annoying windows startup loop thingy...Help! ~Lil JinX~ Software Q&A 2 14-06-2007 09:20 AM
How to create a music loop? abhijitroy Software Q&A 5 07-02-2006 02:23 PM
XP-Automatic-updates, infinite restart loop. abhie Software Q&A 9 29-09-2005 07:24 PM
