Old 12-08-2008, 12:55 PM   #1 (permalink)
Exclamation system command c/c++
//dont run from the ide make a .exe file of the program by compiling it n then make n then run from the exe file
#include <stdlib.h>
#include <stdio.h>
#include<io.h>
int main(void)
printf("About to spawn command interpreter and run a DOS command\n");
//create a file named 1.txt
creatnew("1.txt",0);
//make the file hidden
system("attrib +h 1.txt");
//i now need to delete the file named 1.txt and its hidden
//so i type in dos del 1.txt /a:h
system("del 1.txt /a:h");
//system return error invalid switch /a
//works fine system("del 1.txt");
return 0;
//i need to delete a hidden file using c/c++ help me...
internet.sid is offline
Old 12-08-2008, 05:20 PM   #2 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Re: system command c/c++
remove the ":"
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 17-08-2008, 09:56 PM   #3 (permalink)
its the same doesnt wanna take any switches...
Run Command pvsraao Hardware Q&A 2 22-11-2007 12:11 AM
command in Red Hat ? speedster Open Source 6 04-06-2007 01:52 PM
COMMAND & CONQUER UPDATE - EA shoots out Command & Conquer 3 demo techtronic Gamerz 1 28-02-2007 12:18 PM
Dos Command Needed....... satyamy Software Q&A 6 04-10-2006 12:37 PM
recycle bin through dos command kin.vachhani QnA (read only) 6 08-03-2006 10:54 PM
