Old 29-07-2008, 11:06 PM   #1 (permalink)
Kcots Hserf
trublu's Avatar
Default Java project
I was thinking of making a multimedia player as a part of my Java project.It wud b a basic one,other features wud b added as i learn more.So,the question is,can it b done using Java only? Or do i need to study ne thing else?Pls suggest some useful resources too.
ASUS K53SM-SX0101D | Samsung Wave 525 | Canon EOS 1000D | 18-55 mm | 50mm f1.8
Registered Linux User #471793
trublu is offline
Old 29-07-2008, 11:11 PM   #2 (permalink)
CAFEBABE
chandru.in's Avatar
Default Re: Java project
Java alone is more than enough. You need to use JMF (Java Media Framework) for this.
Chandru
http://tuxychandru.blogspot.com
chandru.in is offline
Old 30-07-2008, 12:31 AM   #3 (permalink)
prasath->loves(APPLE);
prasath_digit's Avatar
Thumbs up Re: Java project
Or check this out, this is source code for a bare-bone command-line Java mp3 player:-
http://www.javalobby.org/java/forums/t18465.html
I've modified the Command-line player with a JFrame window :-
import java.io.FileInputStream;
import java.io.IOException;
import javax.sound.sampled.*;
import javax.swing.*;
import java.awt.*;
import java.awt.event.*;
import java.lang.Thread;
import Limit.*;
public class Jmp3 extends JFrame implements ActionListener
    JButton open,close;
    JFileChooser jfc;
    Jmp3()
       super("Java MP3 Player");
       setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
       setLayout(new FlowLayout());
       setSize(400,300);
       setVisible(true);
       close = new JButton("Close");
       open = new JButton("Open");
       close.addActionListener(this);
       open.addActionListener(this);
       this.add(close);
       this.add(open);
       jfc = new JFileChooser();
       jfc.addChoosableFileFilter(new ImageFilter());
    public void actionPerformed(ActionEvent ae)
       if(ae.getActionCommand() == "Close")
            System.exit(0);
       if(ae.getActionCommand() == "Open")
            play();
    public void play()
        if(jfc.showOpenDialog(this) == JFileChooser.APPROVE_OPTION)
    AudioInputStream din = null;
    try
        FileInputStream file = new FileInputStream(jfc.getSelectedFile());
        AudioInputStream in = AudioSystem.getAudioInputStream(file);
        AudioFormat baseFormat = in.getFormat();
        AudioFormat decodedFormat = new AudioFormat(
                                        AudioFormat.Encoding.PCM_SIGNED,
                    baseFormat.getSampleRate(), 16, baseFormat.getChannels(),
                    baseFormat.getChannels() * 2, baseFormat.getSampleRate(),
                    false);
        din = AudioSystem.getAudioInputStream(decodedFormat, in);
        DataLine.Info info = new DataLine.Info(SourceDataLine.class, decodedFormat);
        SourceDataLine line = (SourceDataLine) AudioSystem.getLine(info);
        if(line != null)
            line.open(decodedFormat);
            byte[] data = new byte[4096];
            // Start
            line.start();
            int nBytesRead;
            while ((nBytesRead = din.read(data, 0, data.length)) != -1)
                line.write(data, 0, nBytesRead);
    catch(Exception e)
        e.printStackTrace();
    finally
        if(din != null)
            try
                                din.close();
                        catch(IOException e)
                                // Nothing here
    public static void main(String[] args)
        new Jmp3();
package Limit;
import java.io.File;
import javax.swing.filechooser.*;
public class ImageFilter extends FileFilter
    public boolean accept(File f)
        String extension = Utils.getExtension(f);
        if (extension != null)
            if (extension.equals(Utils.bpt))
                    return true;
            else
                return false;
        return false;
    public String getDescription()
        return "MP3 Audio File (.mp3)";
class Utils
    public final static String bpt = "mp3";
    public static String getExtension(File f)
        String ext = null;
        String s = f.getName();
        int i = s.lastIndexOf('.');
        if (i > 0 &&  i < s.length() - 1)
            ext = s.substring(i+1).toLowerCase();
        return ext;
Last edited by prasath_digit; 30-07-2008 at 07:00 PM. Reason: To provide source code
prasath_digit is offline
Old 30-07-2008, 10:42 PM   #4 (permalink)
Kcots Hserf
trublu's Avatar
Thankx both of you.
@prasath_amd,thanx for the code.but i prefer to do it myself.
how do i add codec support?
trublu is offline
Old 30-07-2008, 11:29 PM   #5 (permalink)
I gave it only to give u some basic idea tats all.......
don know abt tat.....but i think JMF should do it.......
JMF:-
http://java.sun.com/javase/technolog.../jmf/index.jsp
This may be useful for u:-
http://www.javaranch.com/
Last edited by prasath_digit; 30-07-2008 at 11:33 PM. Reason: Automerged Doublepost
Old 31-07-2008, 09:05 AM   #6 (permalink)
Kcots Hserf
trublu's Avatar
I really appreciate your help.I just said dat i wanna do it myself.
trublu is offline
Old 02-08-2008, 09:48 PM   #7 (permalink)
Indidiot
Plasma_Snake's Avatar
Question Re: Java project
Sorry for budging in but I too have to give a Minor Project after my vacations. I know Core JAVA only and was thinking about making a Torrent Client. Is it possible to make one with my limited knowledge of the subject? Where can i get its exemplary Source Code?
Plasma_Snake is offline
Old 09-08-2008, 09:41 PM   #8 (permalink)
bukaida's Avatar
Search here:-
http://java.codeproject.com/
BTW You must know how to write the project report too. It should follow a specified format.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 09-08-2008, 11:27 PM   #9 (permalink)
i also need to make a java project...i knw basic java programming till applets..i also want to giv it a interface....
shwetz is offline
Old 10-08-2008, 05:45 AM   #10 (permalink)
Commander in Chief
QwertyManiac's Avatar
Learn AWT and then Swing for that.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-09-2008, 11:17 AM   #11 (permalink)
i need hrlp for search engine project on JAVA,,i m begnner for this,,,plzzzzzz
mahender_joshi is offline
Help me on a Java Project redhat Programming 7 01-11-2007 07:07 PM
java project help... Pragadheesh QnA (read only) 2 23-08-2007 10:50 PM
Project in C#.NET or Java ... manas QnA (read only) 1 01-02-2007 02:21 PM
Project in java dreamweaver9962 QnA (read only) 1 19-01-2006 05:48 PM
project in java shivi4 QnA (read only) 3 14-07-2005 05:40 PM
