Old 28-07-2008, 08:15 PM   #1 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Default The Project Euler Thread
Project Euler is is a series of challenging mathematical/computer programming problems that will require more than just mathematical insights to solve. Although mathematics will help you arrive at elegant and efficient methods, the use of a computer and programming skills will be required to solve most problems.
Considering the fact that we have quite a few code junkies here at the Digit Forum, I was thinking maybe we should embark on a journey to solve all of Project Euler's extremely different programs.
Remember, this is a joint effort! Share what you know!
I'm done with the first Nine problems. If someone needs any help with those, holler.
Homer: God bless those pagans.
ring_wraith is offline
Old 28-07-2008, 09:01 PM   #2 (permalink)
18 Till I Die............
Default Re: The Project Euler Thread
Isn't it already there in that competitions thread that has been stickied?
http://www.bash.org/?258908
mehulved is offline
Old 28-07-2008, 09:31 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
A small request though, please don't post a direct spoiler. Never the formula. Takes all the juice of that place out.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 29-07-2008, 02:02 AM   #4 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
I agree. Direction and hints are ok in my view but never ever the solution or a direct answer. It rips out the pleasure in finding the answer yourself.
FilledVoid is offline
Old 29-07-2008, 09:25 PM   #5 (permalink)
=--=l33t=--=
Totally.
Old 13-08-2008, 08:17 PM   #6 (permalink)
hullap's Avatar
^ reported
hullap is offline
Old 14-08-2008, 03:20 AM   #7 (permalink)
MMO Addict
amitava82's Avatar
OMG WTF? this guy managed to post 10 spams and still unbanned
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 26-10-2008, 12:13 PM   #8 (permalink)
Always confused
vamsi360's Avatar
Hello everyone.....
You can use the following thread to post your opinions
http://www.thinkdigit.com/forum/show...018#post975018
Look into it and post if you like....its different.
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Old 27-10-2008, 07:38 PM   #9 (permalink)
Console Junkie
aditya.shevade's Avatar
Okay. No Solutions please. I am on 26 out of 214... Want to do some more.... No time :'(
--- Console Junkie
aditya.shevade is offline
Old 04-11-2008, 09:44 PM   #10 (permalink)
Traceur
zegulas's Avatar
Hey, please someone give the solution to problem 3, in C.
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 04-11-2008, 09:55 PM   #11 (permalink)
Commander in Chief
Skip problems you can't solve. Its not necessary to go in numeric order.
Read up on prime factorization algorithms (Easy ones would do) while you're at it. You can decompose that number and solve it.
Harsh J
www.harshj.com
Old 04-11-2008, 10:14 PM   #12 (permalink)
FilledVoid's Avatar
As a teacher may I recommend one thing. Don't weasel your way through the questions. What good does it do? You don't learn a thing from it and basically you are cheating yourself out of the learning experience. QwertyM has given you a good clue which if you use should give you the answer quite easily.
Maybe if you had a certain question someone could help you further with it .
Old 05-11-2008, 07:15 PM   #13 (permalink)
Mad and Furious
redhat's Avatar
Would anyone please suggest some help on question 4. Largest palindrome as product of two three digit numbers. I do not wish to use brute force and i cant come up with any idea. I tried searching but i found only spoilers and i dont want them
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 05-11-2008, 07:33 PM   #14 (permalink)
Commander in Chief
Express a palindromic number (Its but a simple pattern of mirrored variables?) as a linear equation on a piece of paper and stare at it for some time. Next, use your elite linear equation solving skills to process it to a tidy small equation, and in around next 0.5 minutes of CPU utilization, you should get the answer.
Also use the hint given in the question. Largest.
Harsh J
www.harshj.com
Old 06-11-2008, 02:12 AM   #15 (permalink)
Console Junkie
^^ 0.5 minutes is HUGE... if should be 0.5 cycles (which is impossible, I know )
--- Console Junkie
Old 06-11-2008, 06:43 PM   #16 (permalink)
Commander in Chief
Well I just assumed he's running it on your tiny microprocessor kit
Harsh J
www.harshj.com
Old 09-11-2008, 04:20 PM   #17 (permalink)
Console Junkie
yeah yeah... don't go there... .microprocessors and microcontrollers are for me and meowww... you go and play with your languages and NaCl
--- Console Junkie
Project !! bajaj151 Chit-Chat 5 16-10-2007 01:22 PM
Help for Web Project bazigaar_no_1 QnA (read only) 2 26-06-2007 11:02 PM
A Good Project in PHP for my college project debiprasad_sahoo Open Source 8 15-12-2006 05:31 PM
project in c\c++ shivi4 QnA (read only) 8 05-10-2005 11:19 PM
Project IGI [Project Repair] upendra_gp Gamerz 6 12-06-2005 09:28 AM
