Old 21-07-2008, 04:51 PM   #1 (permalink)
Question switch case in C
hi every1..
how to implement constant expressions using switch statements in C?like we implement expressions using if statement
if(a<b+c) or if((a<b)&&(b<c))........
how can we do it using switch case(rather than implementing constant or character values)?
thinkingon is offline
Old 21-07-2008, 06:08 PM   #2 (permalink)
paralinux
Thumbs down Re: switch case in C
Hello
This may disappoint u but switch case construct is not available in C(as per my knowledge). Its there in C++(I dont know much about C but am comfortable with C++). And in C++ switch case construct is used for constant conditions, it not used for the kind of statements u wish to use it for( oops another disappointment!!!). I hope u know the syntax of the switch case construct.
It accepts a value in the parenthesis of switch and executes the statements under the corresponding case label. If it does not find any then it executes the default statement.
anuvrat_parashar is offline
Old 21-07-2008, 07:01 PM   #3 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Default Re: switch case in C
Switch cannot deal with ranges of value AFAIK. Only with (==) operator.
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 21-07-2008, 09:23 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Use a simple else-if ladder for expression-like conditions. Switch is made for jumping based on a value, else-if is more logical than switch here.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-07-2008, 11:18 AM   #5 (permalink)
Switch can be used only all the possible outcomes of the query are known and the value under comparison cannot be an expression but a constant.
And switch is there in the C library and can be used freely if you know what to do with it.
anshul is offline
KVM Switch... shivg33k Hardware Q&A 1 03-07-2008 02:32 AM
My first Case Mod Artemis Hardware Q&A 45 14-06-2008 05:54 PM
All About Case Fan Revolution Hardware Q&A 1 08-04-2008 09:02 AM
Switch or HUB? linardni QnA (read only) 7 22-08-2005 03:04 PM
should we get a dvd case anirudh QnA (read only) 9 29-10-2004 05:11 PM
