Old 13-07-2008, 11:11 PM   #1 (permalink)
Beware of the innocent
ilugd's Avatar
Default Java-Swing buttons - adding as array in loop problem
SOLVED
I am having trouble with the following code.
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package calcapp;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import javax.swing.event.*;
import javax.swing.border.*;
import java.lang.String;
 * @author jsemmanuel
public class calculator extends JFrame {
    calculator() {
        super("This is a frame");
        setSize(200, 200);
        JPanel valuePanel = new JPanel();
        JPanel buttonPanel = new JPanel();
        JLabel valueLabel = new JLabel("0");
        //valueLabel.setSize(40, 1800); ; //this one doesn't seems to work
        valueLabel.setBorder(new EtchedBorder());
        valuePanel.add(valueLabel);
        String buttonText[] = {"+", "-", "*", "/", "7", "8", "9", "4", "5", "6", "1", "2", "3", "0", ".", "="};
        JButton[] b=new JButton[16];
        for (int i = 0; i < 16; i++) {
           b[i].setText(buttonText[i]);
            buttonPanel.add(b[i]);
        Container container;
        container = getContentPane();
        container.setLayout(new GridLayout(2, 1));
        add("North", valuePanel);
        add("South", buttonPanel);
        addWindowListener(new WindowHandler());
        show();
class WindowHandler extends WindowAdapter implements ActionListener {
    @Override
    public void windowClosing(WindowEvent e) {
        System.exit(0);
    public void actionPerformed(ActionEvent arg0) {
        throw new UnsupportedOperationException("Not supported yet.");
I get this error from the compiler
compile:
run:
Exception in thread "main" java.lang.NullPointerException
        at calcapp.calculator.<init>(calculator.java:32)
        at calcapp.Main.main(Main.java:13)
Java Result: 1
BUILD SUCCESSFUL (total time: 1 second)
The part of the code that is the problem is this.
what i am trying is to create an array of 16 buttons and then go into a loop and assign strings as button labels to each of the individual buttons. I am just learning Java, so not sure what is wrong here. can someone please help?
Life is too short. Have fun.
ilugd is offline
Old 14-07-2008, 12:08 AM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Java-Swing buttons - adding as array in loop problem
Interesting coincidence.. I had the exact same task almost a year back .. but it was in vb.net .. here is the code vb.net
Dim arrButtons(0) As Button 'Prepare array to receive buttons. Give this the necesary scope
Private Sub MyBase_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim btnTemp As Button
        Dim iCount As Integer
        For iCount = 1 To 5
            ReDim Preserve arrButtons(iCount) 'Expand array to receive next buton
            btnTemp = New Button 'Create instance of new button
            btnTemp.Name = "txtBox" & iCount.ToString 'Name button with sequential numbering
            btnTemp.Width = 100
            btnTemp.Text = "button" & iCount
            btnTemp.Location = New Point(20, iCount * 25)
            Me.Controls.Add(btnTemp) 'Add new button to form
            arrButtons(iCount) = btnTemp 'Place reference to new button in appropriate element of array
            'The next line adds the handle of the new button to the appropriate event
            AddHandler btnTemp.Click, AddressOf ButtonClickEvent
        Next
End Sub
Private Sub ButtonClickEvent(ByVal sender As System.Object, ByVal e As System.EventArgs)
    MessageBox.Show(CType(sender, Button).Name & " was clicked")
End Sub
Now in this case I had to create a temperory button object and then assign the properties to this object.. after this just add to the array created. Also add this temp variable to the form/frame.
@ilugd: try the same approach by creating a tempbutton and then adding it to the array/frame. it may work.. BTW im not a java programmer, but doesnt java require a entery point (main()) I guess its in another file in the project .
offtopic: What!!! how did your photo grow a mustache and beard in less than 5 mins?
Check attachment
Charan is offline
Old 14-07-2008, 12:15 AM   #3 (permalink)
CAFEBABE
chandru.in's Avatar
^^ Seems like .Net is too damn same as Java.
@ilugd
When you initialize an array using JButton[] b=new JButton[16], you are just saying that it is an array of 16 JButton instances. You are not actually creating the 16 JButton objects. Hence all elements of array take their default value of null.
To avoid it you must separately initialize each element of the array with a new JButton();
The simple rule to remember in Java is all array elements take their default value upon initialization. The default value for object references if null. Hence you get the most dreaded exception in any Java programmer's life.
Chandru
http://tuxychandru.blogspot.com
chandru.in is offline
Old 14-07-2008, 12:20 AM   #4 (permalink)
ilugd's Avatar
Default SOLVED: Java-Swing buttons - adding as array in loop problem
Thanks a lot charan. You code made me think.
The line
was creating a new JButton array but not the objects at each position of the array. I guess I didn't understand it properly.
In side the loop i just created a new button and assigned it to each array position. The program compiles and works now. Thanks a lot buddy.
            b[i]=new JButton(buttonText[i]);
By the way I am just wondering. Not sure about the syntax of VB.Net, but wouldn't this have been cleaner?
Dim arrButtons(5) As Button
For iCount = 1 To 5
set arrButtons(iCount)= New Button 'Create instance of new button
arrButtons(iCount).Name = "txtBox" & iCount.ToString 'Name button with sequential numbering
arrButtons(iCount).Width = 100
arrButtons(iCount).Text = "button" & iCount
arrButtons(iCount).Location = New Point(20, iCount * 25)
Me.Controls.Add(arrButtons(iCount)) 'Add new button to form
AddHandler arrButtons(iCount).Click, AddressOf ButtonClickEvent
offtopic: Oh, I have been like this since january. just didn't update my avatar. A guy at irc mentioned and I changed it now.
ah, chandru.in, I gained insight just as you were posting. Thanks a lot for confirming my idea.
SOLVED
ilugd is offline
Old 14-07-2008, 12:25 AM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ I didnt use [ /code ] , now i fixed it.
Charan is offline
Old 14-07-2008, 01:19 AM   #6 (permalink)
18 Till I Die............
Default Re: SOLVED: Java-Swing buttons - adding as array in loop problem
And would that be your best friend there?
http://www.bash.org/?258908
mehulved is offline
Old 14-07-2008, 10:06 AM   #7 (permalink)
ilugd's Avatar
and who would that be?
ilugd is offline
The Loop Kingdom abhi.eternal Chit-Chat 1 22-12-2007 07:13 PM
java code at start up and adding playlist.. Pragadheesh QnA (read only) 2 16-09-2007 09:48 AM
array of JPanel in java.... tweety_bird_bunny QnA (read only) 3 27-09-2006 08:52 PM
Learn :: USING JDBC(with ACCESS), AWT, & SWING in JAVA(JDK 1.5) imdbest Tutorials 1 11-07-2006 11:47 AM
HowTo convert C struct with array of another struct in java kb QnA (read only) 1 08-04-2005 12:59 PM
