Old 10-07-2008, 01:21 AM   #1 (permalink)
Question i gt problem in C Program again !!! HELP ME PLS !!!
How do you exchange or swap TWO (2) variables A and B with using a
third or temporary variable?
C program (Attach TWO (2) sample output for each program)
JUST SHOW ME 2 EXAMPLE OF C PROGRAM
ImBeck is offline
Old 10-07-2008, 01:24 AM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: i gt problem in C Program again !!! HELP ME PLS !!!
simple, here is a algo & please code the program yourself
let a=5
b=6
a=a+b
b=a-b
a=a-b
now a=6 and b=5
gary4gar is offline
Old 10-07-2008, 01:29 AM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
another homework..
Charan is offline
Old 10-07-2008, 01:45 AM   #4 (permalink)
 Macboy
goobimama's Avatar
Why're you making a new thread for this? Post it in that thread you've already created about C...
I'm like a bird... :)
goobimama is offline
Old 10-07-2008, 06:19 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
You are seriously asking how to swap with a temporary variable and not without?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-07-2008, 08:38 AM   #6 (permalink)
^^guess not
Faun is offline
Old 10-07-2008, 05:33 PM   #7 (permalink)
Google Bot
Pathik's Avatar
In that case,
x=a;
a=b;
b=x;
PS: Makes me feel like a genius coder.
Pathik is offline
Old 10-07-2008, 05:36 PM   #8 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
another homework obviously.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 10-07-2008, 06:21 PM   #9 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Maybe we should create a separate thread: "Post all your homework questions here"
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 10-07-2008, 07:07 PM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
Only if you pay me for it
gary4gar is offline
Old 10-07-2008, 07:28 PM   #11 (permalink)
MeSmEriZeR
a=a^b;
b=a^b;
a=a^b;
Loading. . .
[███████████] 99%
///Everything which is done in this world is done in
hope///....
coolbuddy is offline
Old 10-07-2008, 07:41 PM   #12 (permalink)
God of Mistakes...
Garbage's Avatar
Originally Posted by coolbuddy View Post
a=a^b;
b=a^b;
a=a^b;
won't "+" or "-" operators suffice ?? I think they are less expensive than "^" ...
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 10-07-2008, 08:04 PM   #13 (permalink)
Commander in Chief
How's addition and subtraction less expensive than an XOR? You've learned your computer architecture properly, haven't you Garbage? It would result in more gate delays than a simple xor.
Harsh J
www.harshj.com
Old 10-07-2008, 08:08 PM   #14 (permalink)
God of Mistakes...
Garbage's Avatar
I thought he meant "raise to"
thought it's algorithm than statements...
Garbage is offline
Old 10-07-2008, 10:55 PM   #15 (permalink)
GaurishSharma.com
gary4gar's Avatar
yep, Bitwise operations are fastest.
but this things are never taught in our education system
what we learn is using a two and a half decade old program called "TC"
gary4gar is offline
Old 11-07-2008, 06:55 AM   #16 (permalink)
cooldip10's Avatar
a thread named "HOMEWORK HELP" must started
This will save space + other's problems can be reviewed without having to use the search engine
Everything is Possible
cooldip10 is offline
Old 23-07-2008, 09:22 PM   #17 (permalink)
jal_desai's Avatar
dont u think the question deserved no more than 2 posts.. (this applies to me also for posting this useless post)
TechExplorer.in
jal_desai is offline
Halo ladies and gentleman , i gt problem with this C program can help me ? ImBeck Programming 17 11-07-2008 07:28 PM
Problem encryption program in c++ Shikher_neo Programming 11 21-05-2008 02:14 PM
java smiley program problem ratedrsuperstar Programming 1 14-05-2008 09:53 AM
END PROGRAM PROBLEM kumarn_2004 QnA (read only) 2 11-12-2005 04:54 PM
