Old 27-06-2008, 03:26 PM   #1 (permalink)
jal_desai's Avatar
Default How to open "My Computer" through a JAVA code??
hi all... i want to open "My Computer" window through a Java Code... i m not able to find the code...
i also wanted to open windows media player through a java code.. and i got success in it.. i used the Process process = Runtime.getRuntimeexec("c:/pro.../../wmplayer.exe"); ... BUT this is possible only if we know the place where the exe is located... and MY COMPUTER is not an exe... i know tht it has a CLSID key which needs to be run in explorer... so can anyone tell me how to run a clsid key from within a JAVA code???
thnks
TechExplorer.in
jal_desai is offline
Old 28-06-2008, 03:10 PM   #2 (permalink)
CAFEBABE
chandru.in's Avatar
Default Re: How to open "My Computer" through a JAVA code??
I don't think it is possible to open "My Computer" itself as it does not have a path in Windows Operating System. However, if you want to open a specific directory using the Operating System's default file manager, you can try the following code. It works in a completely platform independent manner, unlike the Runtime.exec() method invocation.
package main;
import java.awt.Desktop;
import java.io.File;
import java.io.IOException;
import javax.swing.filechooser.FileSystemView;
public class Main {
    public static void main(String[] args) throws IOException {
        Desktop desktop = Desktop.getDesktop();
        File dirToOpen = new File("C:\\some_directory");
        desktop.open(dirToOpen);
If you want to open the default directory for current user ("My Documents" on Windows and user's home directory on Linux and UNIX), you can use the following code to get a File object for the default directory.
File defaultDirectory = FileSystemView.getFileSystemView().getDefaultDirectory();
Hope it helped you a bit.
Note: The Desktop class used above is available from Java 6.
Chandru
http://tuxychandru.blogspot.com
chandru.in is offline
Old 28-06-2008, 03:22 PM   #3 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
http://forum.java.sun.com/thread.jsp...sageID=4158322
गीक होना माँगता
victor_rambo is offline
Old 28-06-2008, 09:11 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
My computer is not an exe, but Explorer.exe is!!
try:
Process process = Runtime.getRuntimeexec("C:/Windows/Explorer.exe");
and for opening the users/documents and settings folder for any user, run
yeah put that in the run box and press enter. It might work with the above function, try it.
dheeraj_kumar is offline
Pen drive error messg"Unable to open Script file "F:\MSDLL.dll.vbs" janitha Software Q&A 19 20-04-2007 10:25 PM
"Search" is the first option instead of "Open" Rooney Software Q&A 4 31-01-2007 01:28 PM
Intel debuting long delayed Chip code-named "Montecito" JGuru Technology News 2 20-07-2006 10:39 PM
Microsoft Windows: The End of "My" in "My Computer" Sourabh Software Q&A 14 09-06-2005 11:42 AM
