Old 25-06-2008, 04:59 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question ASP.NET 1.1 in 2.0
Hi,
I have Visual Stuio 2005 but now wanna work on 1.1 projects
so,cant open the solution file in 2.0...Is there any way i can work on 1.1 thru
VS 2005
whats the solution 4 this ???
Zangetsu is offline
Old 25-06-2008, 08:38 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: ASP.NET 1.1 in 2.0
Follow the migration tool, your application would work with 1.1 too, if present in the target system.
http://blogs.msdn.com/peterlau/archi...11/595294.aspx
Harsh J
www.harshj.com
QwertyManiac is offline
