Old 24-06-2008, 02:25 PM   #1 (permalink)
Default Better solution
Some good question asked at rgec meerut.You can download their solution at
http://www.goelc.blogspot.com/
please provide me better solution for these questions
Phase 1
Q:1‐>WAP TO FIND OUT THAT IS NO IS POWER OF TWO OR NOT. (WITHOUT USING LOOP)
Q:2‐> WAP TO PRINT THE ALL COMBINATION OF STRING “ABC”.
Q:3‐>WAP TO DO THE SUM OF ALL DIGITS OF A NO UNTILL ANS HAS ONLY ONE DIGIT(WITHOUT
USING LOOP)
EX:‐5699
=>5+6+9+9=29
=>2+9=11
=>1+1=2
Q:4‐>WAP TO PRINT STRUCTURE LIKE
1
2 2
3 3 3
4 4 4 4
Q:5‐>WAP TO REMOVE THE FROM THE SENTENCE ENTER BY THE USER.
EX:‐> THIS IS THE TABLE.
=>THIS IS TABLE
PHASE 2
Q:1‐>WAP TO PRINT THE FILE NAME FROM WHICH PROGRAM IS EXECUTED.
Q:2‐>WAP TO MAKE A STRING PALINDROME
EX:‐>IIT
=> ITI
Q:3‐>WAP TO PRINT SPARSE MATRIX
EX:‐>
1 2 3 4
12 13 14 5
11 16 15 6
10 9 8 7
goelvivek is offline
Old 25-06-2008, 09:13 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Better solution
P1:
1. Number & Number-1 == 0 (For Number to be power of 2)
2. Permutation Algorithm at Wikipedia or look for an example with standard C++ here.
3. You're using recursion instead of loop. Clever enough I'd say.
4. Triangles, meh. Anything that gives that output will do.
5. String Class function - replace (C++). Replace "THE " with "" and for safety, check "THE" with "" too. ("" is null string, and the second "THE" is without the trailing space)
Will check up on Phase 2 later, but by the looks of it, its good enough. Not checked in detail as I haven't attempted the last two ones yet.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-07-2008, 03:09 PM   #3 (permalink)
i m waiting for your second phase answers
Please tell me the solution. mobilogist Software Q&A 4 03-05-2008 06:38 AM
Best Solution eggman Chit-Chat 7 26-08-2007 08:04 PM
Need a solution rajas700 Open Source 1 07-09-2005 12:23 AM
Need a solution rajas700 QnA (read only) 3 26-08-2005 09:14 PM
