Old 19-06-2008, 09:41 AM   #1 (permalink)
~[::BOoYaKa::]~
Default Little Javascript/Cookie Help..
Hi people.. I have a little problem.. I need to put a javascript code in a html file, which when viewed, get the cookies of the viewer and store them in a remote txt file..
i know we can get the cookies with this -
javascript:alert(document.cookie)
or
javascript:document.write(document.cookie)
but how to store the value of
(document.cookie)
in a txt file which is located at, say, http://www.blah.com/logs/logs.txt??
I hope you understand.
Thanx.
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 19-06-2008, 01:19 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Little Javascript/Cookie Help..
Before I can help you, I need to know why you want to store all cookies of an visitor? Cookies may contain critical information and be used for illegal activities. In plain words, you are violoating your visitors privacy.
गीक होना माँगता
victor_rambo is offline
Old 01-07-2008, 04:36 PM   #3 (permalink)
Perpetual Fresh Stock
siddes's Avatar
You cannot store the cookies in a file through Javascript, unless you use JScript and your target uses Internet Explorer.
http://sid-deswal.110mb.com
No clever lines here, go think them up yourselves.
siddes is offline
Old 01-07-2008, 08:20 PM   #4 (permalink)
हॉर्न ओके प्लीज़
he wants to store it in a 'remote' file.
गीक होना माँगता
Old 02-07-2008, 03:25 AM   #5 (permalink)
MMO Addict
amitava82's Avatar
you have to use server side scripting language in order to be able to write data to server. Here is how you do it with PHP:
PHP Code:
<?php
$filename
rand(0000,9999).'.txt';
$filehandler fopen($filename,'w');
$cookies print_r($_COOKIEtrue);
fwrite($filehandler,$cookies);
fclose($filehandler);
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
help needed in cookie!!! prinz QnA (read only) 13 16-07-2007 05:06 PM
Is it a DIGIT cookie or... koolbluez QnA (read only) 11 11-02-2007 09:20 PM
how to allow cookie? mandar5 QnA (read only) 2 04-10-2006 02:09 AM
enable cookie in IE royal QnA (read only) 6 02-10-2006 08:32 PM
Cookie Duration? Generic Superhero QnA (read only) 3 15-10-2005 04:56 PM
