Old 18-06-2008, 01:01 AM   #1 (permalink)
Default Help a beginner in Java!!
Hello! to all tech enthusiasts.well iam a beginner programmer in Java currently learning it on my very own.Ihave got an extremely simple but very important question.I recently started using Windows Vista Home premium and downloaded JDK 6.0.But I find that many commands such as "javac" are not recognised by the system and infact I have not been able to run any program correctly till now on my new PC.Please can anyone give me some information as to how I can start using Java on my PC??
anuragsinha is offline
Old 18-06-2008, 06:09 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help a beginner in Java!!
start->run "cmd"
navigate to the folder where you installed jdk. then go to \bin.
now you can use javac and java.
dheeraj_kumar is offline
Old 19-06-2008, 08:43 AM   #3 (permalink)
anomit's Avatar
change your PATH environment variable. I have never used Vista but if I was in XP, I'd have done the following from the command prompt:
SET PATH=%PATH%;D:\java\bin
assuming you have installed the jdk at D:\java
Don't think things would be much different in Vista..
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 19-06-2008, 09:14 AM   #4 (permalink)
The rated R superstar.
Pls set the path and the class path.
create a .bat file and put the path and classpath the go to cmd and run thr .bat file.
set path=;E:\Java\jdk1.7.0\bin;%path%
set classpath=;E:\Java\jdk1.7.0\src.jar;.;E:\Java\jdk1 .7.0\lib\dt.jar;.;E:\Java\jdk1.7.0\lib\tools.jar;% classpath%
I'm very responsible, when ever something goes wrong they always say I'm responsible.
roshan1236a is offline
Old 19-06-2008, 07:48 PM   #5 (permalink)
Tired of being sorry!
quad_master's Avatar
Lightbulb Re: Help a beginner in Java!!
typical path problem dude!! if u open a console & set the PATH variable...bingo! u r done!! but i think when u exit form that console...setting will gone!!
so u need to fix this up permanently...
RClick on mycomputer > properties > advanced > environment variables > user variable/system variable section's NEW button > it'll ask for 'variable name' & 'value'
set 'variable name' to PATH & it's value to the java's 'bin' directory...save the changes...u r done!
There are 10 types of people in this world, those who understand binary and those who do not.
quad_master is offline
Old 19-06-2008, 08:30 PM   #6 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^absolutely right.
n00b forever...
~Phenom~ is offline
Guide for beginner how to convert video to psp jane1043 Tutorials 1 17-01-2010 10:39 AM
Java programming..how can I distribute java program....? Manojap Programming 5 16-05-2009 02:46 PM
What is more powerfule Core Java or Java ? avadhesh QnA (read only) 4 06-05-2008 04:55 PM
MSDN Launches Beginner Programmers Site Third Eye Technology News 7 03-03-2007 07:44 PM
Beginner’s Guide: Run Linux like any other program in Windows subratabera Open Source 15 02-02-2007 10:58 PM
