Re: Bloodshed help!
You sound like a noob. I dont mean to insult you, but Im just saying you have a lot to learn.
You dont PLUNGE into graphics or windows design. You will get nowhere. You have to start with C, move on to C++, and then go ahead with windows programming, and then graphics programming. If you are not strong in c and c++, you'll fail when it comes to windows prog.
If you really want to learn programming, get Turbo C++ and learn C and C++. Then move on to Microsoft Visual C++ and learn Windows SDK prog, then MFC, then CLR, and sideby side learn graphics while you are doing so.
