10-06-2008, 05:11 PM
Anyone using NetBeans IDE
Can NetBeans IDE be used for compiling simple C++ programs? Whenever I try to compile any C++ program, it says makefile has not been added.
10-06-2008, 05:38 PM
Indidiot
Re: Anyone using NetBeans IDE
I don't think so coz as far as I've used Netbeans IDe, which is limited BTW, one can use it for inly Java. Use Visual Studio if want an all in one package for C,C++,C# etc.
10-06-2008, 08:12 PM
* Teh Flirt King *
Yes..NetBeans IDE can be used for C/CPP coding..
http://www.netbeans.org/features/cpp/index.html
I use eclipse though (for java).
10-06-2008, 08:46 PM
yes but u will have to install a c compiler before using it
e.g.: cygwin or migwin
11-06-2008, 01:59 PM
^^I provided DEV-CPP as compiler to Netbeans(under options) but still It gives a message that says MAKEFILE hasn't been included and it doesn't compile program.
Rudick, DevCPP can be used for a number of languages like Java, C++, Ruby etc.
11-06-2008, 02:19 PM
18 Till I Die............
makefile isn't same as the compiler. I don't know how to solve the problem but this might help you. This site explains what is make - http://www.eng.hawaii.edu/Tutor/Make/
http://www.bash.org/?258908
11-06-2008, 05:47 PM
The rated R superstar.
Oh ye u can.
I'm very responsible, when ever something goes wrong they always say I'm responsible.
12-06-2008, 10:19 AM
^^But how. Unable to remove the error
12-06-2008, 11:20 AM
Commander in Chief
Its best, for simple programs of any language, to never use an IDE.
Anyway lets follow what they have to say:
http://www.netbeans.org/kb/60/cnd/quick-start.html
Harsh J
www.harshj.com
13-06-2008, 09:49 AM
^^I have already read that but unable to get my problem solved. Why do you think IDE should not be used?
13-06-2008, 11:35 AM
Commander in Chief
You waste more time on configuring it for things that are way beyond the level you ought to start with, just like you are doing now! When you do projects you will require makefiles and such but for now quit it and use any simple editor (Notepad++ or gedit and those kind, or cli if you prefer), and use the g++/cc/etc commands to compile
Harsh J
www.harshj.com
13-06-2008, 08:39 PM
dev cpp will not work as netbeans requires a C compiler, C++ compiler, make utility, and gdb debugger all of which Dev cpp doesn't have.
try cygwin and follow instructions from here.
http://www.netbeans.org/community/re...tructions.html
If you are a beginner then try using a simple editor as people have recommended(Nodepad++ is a great one).
14-06-2008, 05:15 PM
i am unable to set path in j2DK .... the script gets compiled but i ma unable to run the script ...it says noclasdeffound.....like plz ..help me guys ./..trying from so many days !!
25-07-2008, 01:09 PM
prasath->loves(APPLE);
Unless ur working on Linux consider using VC++ 2008 Express its totally free and comes with .NET FrameWork 3.5
