Old 12-05-2008, 05:08 PM   #1 (permalink)
Default sorting problem??? help please...
hey guys,
i am doin this program for sorting two-dimnsional aray in ascendin order, and it should accpt N inputs from user... whr N is 7
this is what i have done so far....
void sortLastNames(char name[][N], int N)
int count, count1;
char tempname[20];
for(count=0; count<N-1;count++)
for(count1=count+1;count1<N;count1++)
if(strcmp(name[count], name[count1])>0)
strcpy(tempname, name[count]);
strcpy(name[count], name[count1]);
strcpy(name[count1], tempname);
now problem is it runs smoothly if u enter input with upto 6 characters, if u enter more than that, it crashes....
please guys reply me back ASAP...
jdesai18 is offline
Old 12-05-2008, 11:43 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: sorting problem??? help please...
...;count<N-1;...
If N==7, shouldn't you simply count upto N viz count<N such that it goes from 0 ... 6?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-05-2008, 11:10 AM   #3 (permalink)
nightcrawler's Avatar
Originally Posted by jdesai18 View Post
hey guys,
This is the reason for it. The above statement means that sortLastNames takes an array of Strings (or 2d array of char). The size of each string is N that is 7. Hence whenever a string greater than 7 is encountered strcmp and strcpy will cause problems.(They have overflow issues as they look for NULL terminating strings '\0').
Fixing this will solve ur problem.
Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
nightcrawler is offline
Old 13-05-2008, 02:25 PM   #4 (permalink)
18 Till I Die............
Gives me compile time error with gcc.
http://www.bash.org/?258908
mehulved is offline
how to disable vista auto sorting files ranjan2001 Software Q&A 1 15-04-2008 12:53 PM
sorting passwords in firefox vicky_l7 Internet & WWW 3 07-09-2007 10:25 PM
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
MS Excel worksheet columns not SORTING-PROBLEM MERGED CELLS TVB RAJU Software Q&A 1 29-07-2005 12:50 PM
