Old 01-05-2008, 03:02 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ayush_chh's Avatar
Default adding help file to vb project
hi guys!
i am doing my VB project right now and got this problem. i have successfully compiled a help file ( .chm) and i have also linked that file in HelpFile of project. so i get the helpfile whenever i press F1.
what i want to do is , i have a menu 'Help' and i want to load this help file when i click on this Help menu. i.e click event of this menu.
pls help ......its urgent....
thanks
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 01-05-2008, 08:16 AM   #2 (permalink)
ruturaj3's Avatar
Default Re: adding help file to vb project
use shell command.
ruturaj3 is offline
Old 01-05-2008, 06:07 PM   #3 (permalink)
Amir.php's Avatar
Thumbs down Re: adding help file to vb project
use the help common dialog box
Amir.php is offline
Old 01-05-2008, 10:31 PM   #4 (permalink)
ayush_chh's Avatar
i have tried it but that's not working......may be i m doing something wrong......can u explain me the way.......
Originally Posted by ruturaj3 View Post
use shell command.
Old 02-05-2008, 07:14 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Shell "winhelp /path/helpfile.hlp", vbnormalfocus
http://www.freevbcode.com/ShowCode.asp?ID=2228
Add the code to the menu. Thats the only difference.
dheeraj_kumar is offline
Old 02-05-2008, 06:54 PM   #6 (permalink)
ayush_chh's Avatar
can i also use this with .chm files
like shell "winhelp /path/helpfile.chm", vnnormalfocus
Old 02-05-2008, 08:17 PM   #7 (permalink)
Yes, because winhelp supports .hlp and .chm
Old 04-05-2008, 09:54 PM   #8 (permalink)
ayush_chh's Avatar
it gives me an error....... .chm not supported by winhelp......
what can be the problem???
LinkBack to this Thread: http://www.thinkdigit.com/forum/programming/86691-adding-help-file-vbulletin-project.html
sunshineavi's CLP1 Bookmarks on Delicious This thread Refback 29-09-2010 12:16 PM
[B]Adding A RAM[/B] sudipapd QnA (read only) 1 21-11-2007 07:48 PM
To use MS ACCESS (XP) data file in vb6 project anilvc31 Software Q&A 1 15-05-2007 03:09 PM
A Good Project in PHP for my college project debiprasad_sahoo Open Source 8 15-12-2006 05:31 PM
ADDING A NEW HDD!!!!!!!!!! gary4gar QnA (read only) 1 03-10-2005 03:16 PM
Project IGI [Project Repair] upendra_gp Gamerz 6 12-06-2005 09:28 AM
