Old 24-04-2008, 11:59 PM   #1 (permalink)
Tushar.bar's Avatar
Question Matrix multiplication in java
HI all , one of my friend was challenged by me that to make a program to multiply two matrix and display result.
but rule is using only one one dimensional array.
he wright the prog in java, but i don't know java(only c,c++)
so can any check that
1>Is the code is working?
2>How many array he takes for it?
3>how many array he use?
void forkJoinMatrixMultiply(
final double[][] a,
final double[][] b,
final double[][] c) {
check(a,b,c);
final int m = a.length;
final int n = b.length;
final ParallelDoubleArray cols = ParallelDoubleArray.createUsingHandoff(b[0],
ParallelDoubleArray.defaultExecutor());
cols.replaceWithMappedIndex(new Ops.IntAndDoubleToDouble() {
public double op(final int j, final double element) {
final double[] Bcolj = new double[n]; // allocated inside the op, not "outside the loop"
for (int k = 0; k < n; k++) {
Bcolj[k] = b[k][j];
for (int i = 0; i < m; i++) {
final double[] Arowi = a;
double s = 0;
s += Arowi[k] * Bcolj[k];
c[j] = s;
return element;
Tushar.bar is offline
Old 01-05-2008, 11:52 AM   #2 (permalink)
JGuru's Avatar
Default Re: Matrix multiplication in java
@Tushar,
Here goes the code for Matrix Multiplication in Java language.
 //MatrixMultiplication.java
 *  Compilation:  javac MatrixMultiplication.java
 *  Execution:    java MatrixMultiplication
 *  6 different ways to multiply two N-by-N matrices.
 *  Illustrates importance of row-major vs. column-major ordering.
 *  $ java MatrixMultiplication 400
 *   @author JGuru  05-02-2006
 *  Generating input:  0.765 seconds
 *  Order ijk:   7.875 seconds
 *  Order ikj:   14.542 seconds
 *  Order jik:   7.838 seconds
 *  Order jki:   20.86 seconds
 *  Order kij:   13.132 seconds
 *  Order kji:   20.813 seconds
public class MatrixMultiplication {
    public static void main(String[] args) {
        int N = Integer.parseInt(args[0]);
        long start, stop;
        double elapsed;
        // generate input
        start = System.currentTimeMillis();
        double[][] A = new double[N][N];
        double[][] B = new double[N][N];
        double[][] C;
        for (int i = 0; i < N; i++)
            for (int j = 0; j < N; j++)
                A[i][j] = Math.random();
                B[i][j] = Math.random();
        stop = System.currentTimeMillis();
        elapsed = (stop - start) / 1000.0;
        System.out.println("Generating input:  " + elapsed + " seconds");
        // order 1: ijk = dot product version
        C = new double[N][N];
                for (int k = 0; k < N; k++)
                    C[i][k] += A[i][j] * B[j][k];
        System.out.println("Order ijk:   " + elapsed + " seconds");
        // order 2: ikj
        System.out.println("Order ikj:   " + elapsed + " seconds");
        // order 3: jik
        System.out.println("Order jik:   " + elapsed + " seconds");
        // order 4: jki = GAXPY version
        System.out.println("Order jki:   " + elapsed + " seconds");
        // order 5: kij
        System.out.println("Order kij:   " + elapsed + " seconds");
        // order 6: kji = outer product version
        System.out.println("Order kji:   " + elapsed + " seconds");
        // order 7: jik optimized ala JAMA
        double[] bj = new double[N];
        for (int j = 0; j < N; j++) {
           for (int k = 0; k < N; k++) bj[k] = B[k][j];
              for (int i = 0; i < N; i++) {
                 double[] ai = A[i];
                 double s = 0;
                 for (int k = 0; k < N; k++) {
                     s += ai[k] * bj[k];
                 C[i][j] = s;
Java is very similar to C/C++ (by intent). If you know C/C++, you should be very
comfortable in Java in no time. Java goes a step higher ,compared to these
languages in terms of simplicity, OOPS, reusability, inheritance, Core Classes,
platform independence etc.,
You can get a Java book like Java 2: The Complete Reference to get familiar
with Java in no time!!!
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 01-05-2008, 11:58 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
But JGuru, he didn't ask for a program, but just an explanation of that code his friend gave him.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-05-2008, 05:59 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Exact replica of
http://www.cs.princeton.edu/introcs/...tion.java.html
and added your name onto it.
Please mention sources next time, and try not to take credits for other people's work.
dheeraj_kumar is offline
Old 01-05-2008, 06:05 PM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
Look at this code..
final double[][] a,
final double[][] b,
final double[][] c
Aren't they 3 two-dimensional arrays ??
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 07-05-2008, 09:51 AM   #6 (permalink)
Tushar.bar's Avatar
Red face Re: Matrix multiplication in java
^^^ya i think so.
Old 07-05-2008, 02:30 PM   #7 (permalink)
Oh thats right, so how about storing a 2D array in a 1D array? Like for a n-column matrix, [i][j] = [n*i + j] Does anyone get what I'm talking about?
What do you want in Matrix 4 ? Batistabomb Chit-Chat 7 28-01-2008 01:03 PM
THE MATRIX TRILOGY RETURNS - Hi-def Matrix trilogy goes to HD DVD this spring, Blu-ra techtronic Technology News 19 29-03-2007 04:17 PM
The Matrix: PON moshel Gamerz 4 16-10-2006 06:22 PM
Speed Multiplication on Dial-Up? How's it possible? DKant QnA (read only) 4 14-04-2005 12:47 PM
The Matrix: Path of Neo tarey_g Gamerz 20 21-03-2005 07:09 PM
