Old 17-04-2008, 03:38 PM   #1 (permalink)
Linux Learner
PcEnthu's Avatar
Wink Swap two numbers without using a temporary variable
Ok guys. Here is the problem. There are two variables x and y which hold numbers. You have to swap the value of the two variables. U might say, just store the value of x in a temporary variable z, store value of y in x and finally store z value in y Here is the tricky part, u have to do it without using the variable z
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
PcEnthu is offline
Old 17-04-2008, 03:51 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Swap two numbers without using a temporary variable
x=a
y=b
x=x+y
y=x-y
x=x-y
show x,y
mediator is offline
Old 17-04-2008, 03:54 PM   #3 (permalink)
Kalyan's Avatar
x,y be the nos.
1) x=x+y
2) y=x-y
3) x=x-y
u got them swapped.
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 17-04-2008, 03:55 PM   #4 (permalink)
Not fresh
VINSTAR's Avatar
x=x+y
y=x-y
x=x-y
gudz.org
VINSTAR is offline
Old 17-04-2008, 03:58 PM   #5 (permalink)
Think Zen.
ray|raven's Avatar
You can even use division and multiplication operators.
x=x*y
y=x/y
x=x/y
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 17-04-2008, 03:58 PM   #6 (permalink)
Linux Learner
PcEnthu's Avatar
@ all u guys, That was fast and u got that cracked that easily. Well done. I will try to come up with some level up questions later.
PcEnthu is offline
Old 17-04-2008, 03:59 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Or if you wish to do it the l33t way, use XOR.
Starting with x=10, y=20
x^=y
y^=x
x^=y
Now x=20 and y=10.
Logic's the same as addition mostly, except its bitwise.
Edit: This a challenge or a homework question? For challenges, there exists a thread, I hope you can revive it with better questions than the ones already present.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-04-2008, 03:59 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
// 'a' and 'b' are the two variables.
a=a^b
b=a^b
a=a^b
http://twitter.com/blueshift155
blueshift is offline
Old 17-04-2008, 04:03 PM   #9 (permalink)
Linux Learner
PcEnthu's Avatar
x=x*y
y=x/y
x=x/y
That would work for positive and negative numbers and not for zero
PcEnthu is offline
Old 17-04-2008, 04:12 PM   #10 (permalink)
Think Zen.
ray|raven's Avatar
^Yep. Thats one limitation, by using div.
Old 21-04-2008, 12:20 PM   #11 (permalink)
yeah...XORing is much better as compared to other suggested methods(here).
Other methods may not work if we are dealing with MAX possibles values of respective data types which results in overflow..so,
if(a!=b) ///if a==b, no need of swapping values
a^=b^=a^=b;
swaps the values in a and b
cheers
Jove is offline
Old 22-04-2008, 10:27 AM   #12 (permalink)
x = 2
y = 4
y = y-x = 2
x = y+y = 4
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 22-04-2008, 10:32 AM   #13 (permalink)
Think Zen.
ray|raven's Avatar
Originally Posted by Desi-Tek.com View Post
x = 2
y = 4
x = y-x = 2
y = x+x = 4
Lolz, that works only for those no's i guess.
Try these,
x=5
y=7
x = y-x = 7-5 = 2 ?
y = x+x = 2+2 = 4 ?
Crappy logic.
Old 22-04-2008, 10:46 AM   #14 (permalink)
i can do that in a single statement.. swap two number in w/o temp var
x ^= y ^= x ^= y;
This swaps the two varaibles... OF course in c and other languages which support bit wise operators..!!
hariharan is offline
Old 22-04-2008, 10:54 AM   #15 (permalink)
Commander in Chief
@rayraven - Lol! By the way, D-Tek.com and Dheeraj are one and the same I think.
x = 2
y = 4
x = y-x = 2
y = x+x = 4
Hahah, moreover you started with x=2 and y=4 and ended with the same
Harsh J
www.harshj.com
Last edited by QwertyManiac; 22-04-2008 at 10:54 AM. Reason: Automerged Doublepost
Old 22-04-2008, 10:59 AM   #16 (permalink)
Think Zen.
ray|raven's Avatar
^Lolz, i missed that part
What was he thinking while writing it?
I've known guys who try to deduce logic from examples.
Crappy way, if you ask me. 99% of the time you end up with a logic that works only for the example.
Old 22-04-2008, 02:43 PM   #17 (permalink)
oh sorry i am awake from 24 hour
public
class Swap{
staticvoid swap(int x,int y){
//int temp=x;
x^=y; //2
y^=x; // 5
x^=y; //7
System.out.println("After swapping x = " + x + " y = " + y);
publicstaticvoid main(String[] args){
int x=5;
int y=7;
System.out.println("Before swapping x="+x+" y="+y);
swap(x,y);
//one line logic
public class Swap{
static void swap(int x,int y){
y=(x+y)-(x=y);
System.out.println("After swapping x= " + x + " y = " + y);
public static void main(String[] args){
int x=5;
int y=7;
swap(x,y);
Dhiraj Thakur
Old 22-04-2008, 07:07 PM   #18 (permalink)
Console Junkie
aditya.shevade's Avatar
LOL this has been discussed before....
anther way apart from the XOR way is,
b = a + b - (a = b); you are done.
--- Console Junkie
aditya.shevade is offline
Old 22-04-2008, 10:25 PM   #19 (permalink)
I have Yolks not Brains!
eggman's Avatar
x = 2
y = 4
x = y-x = 2
y = x+x = 4
Ha ha ha ha ha ha ha ha ha ha ha ha ha ha
I've never seen a post funnier and noobier than this!!!!!
Y U NO ALLOW PICTURES IN SIGNATURES?
eggman is offline
Old 24-04-2008, 10:12 AM   #20 (permalink)
18 Till I Die............
I have.
http://www.bash.org/?258908
mehulved is offline
Old 28-04-2008, 09:42 PM   #21 (permalink)
Console Junkie
Oi mehul.... he said he has not... he did not say you have not....
--- Console Junkie
Old 29-04-2008, 01:22 PM   #22 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
In Ruby:
b,a = a,b
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 29-04-2008, 01:23 PM   #23 (permalink)
Think Zen.
ray|raven's Avatar
Sarcasm perhaps?
Old 29-04-2008, 09:11 PM   #24 (permalink)
Console Junkie
^^ yeah... I guess
Was it Mehul?
--- Console Junkie
Old 29-04-2008, 11:56 PM   #25 (permalink)
Vivek788's Avatar
well u can use these in a loop or condition statement like the if or for to avoid a semicolon.
Viva Green Computing!!
http://www.vivtech.blogspot.com/
Vivek788 is offline
prob wid double variable prancks Programming 5 08-04-2008 04:11 PM
how add environment variable in ubuntu mak1012 Open Source 17 17-09-2007 05:48 PM
cant declare a string variable... geekgod Open Source 13 12-08-2006 06:09 AM
In Excel How to use cell ref as a variable abhijitroy Software Q&A 1 10-07-2006 02:32 PM
Temporary C++ amnesia 8| DKant Programming 7 07-02-2005 10:28 PM
