hi all,
i'm very new to java programming ( or u can say i kno nothing).
i hav a mobile calendar project which is running fine on mobile and i want 2 run it on pc. i'm trying 2 open it in java wireless toolkit 2.5.2
it loads properly using .jad file, but when i build it gives error :
build failed
no sources to compile
plz can any1 tell me whats the prob, am i using wrong tool 2 open it??
plz help me out.
