Old 07-04-2008, 03:38 PM   #1 (permalink)
Shikher_neo's Avatar
Default help wid /n
hey, i have some prob wid da /n character.well as u know during output to a file a /n is converted into 2 characters.it increases the size and hense i am having prob in appending data through the for loop.using binary completely deleted all the /n.
please help me
God Does Not Play Dice
-Albert Einstein
Shikher_neo is offline
Old 07-04-2008, 03:59 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: help wid /n
I am sure what you need, but if you are speaking about the 'newline' delimiter, then its "\n" and not "/n". You are using forward slash instead of back slash.
गीक होना माँगता
victor_rambo is offline
Old 08-04-2008, 04:11 PM   #3 (permalink)
Yeah, true. Use \n instead of /n
Aakash Shah
aakash is offline
Old 08-04-2008, 04:17 PM   #4 (permalink)
/n will be equal to two characters. One for '/' and other for 'n'
ThinkFree is offline
Old 13-04-2008, 05:55 PM   #5 (permalink)
Default Re: help wid \n (also-how 2 display * during input ? )
sorry for the backslash.I actually meant \n.But i know it occupies 2 bytes one for the carriage return and another for line feed.But it is converted back to single char during input and 2 chars during output.so this is posing a prob.when i input a file to make some changes send it back and another program needs it for the same purpose because now the size is changed. please help.
ANOTHER THING
can someone suggest a way to display * instead of a character during input ie the password field in Console programs?
-Albert Einstein
Old 13-04-2008, 06:07 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Use a non echoing getchar() method. And for each character grab, send * to stdout. It depends on your platform though, on Linux I use curses/ncurses for achieving this (noecho() function).
And same goes for your \n. Windows does the 2 things - Carriage Return and Line Feed (CRLF), while on Linux it'd just be a single Line Feed (LF), and on Macintosh it is just a Carriage Return (CR). Windows is the only one doing both characters.
I guess you can intercept that behavior since you know it happens that way?
P.s. What language? Some have inbuilt password masking functions.
P.p.s. I just realized that \n is just for newline, and not for carriage return too, which is \r. So I don't know how its occupying 2 bytes if its not specified to, maybe its Windows indeed at work? Perhaps use \n\r together to avoid this confusion.
Harsh J
www.harshj.com
QwertyManiac is offline
