Old 07-04-2008, 01:47 PM   #1 (permalink)
Default hibit8-7 problem
i have installed hibit program on my computer to hide my data...and now its a trial for 10 times using only..i have over used it for eleven times and the problem now is i can't get back my hide data on hibit. i also try find solution at http://www.theeldergeek.com/forum.. and found a solution ..it tells me download unlocker and delete csrss.exe that the hibit use...im made a mistake here where i just move one data/folder and keep it to my desktop and not all the hide data/folder...after that i have delete that csrss.exe...and now i have get back only one data/folder on the hibit.....is there any solution for me?...i really need all my data/folder that i hide using hibit program...
ronster5039 is offline
Old 09-04-2008, 10:42 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: hibit8-7 problem
Point us to the solution you tried out exactly please. Wrong section.
Porn's recoverable over time I assume.
Harsh J
www.harshj.com
QwertyManiac is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
