Old 20-03-2008, 07:11 PM   #1 (permalink)
mihir2608's Avatar
Default Problems in IE
i made a website(not yet uploaded..hence nothing more than a collection of few htmls pages) few days ago and subsequently kept on changing the layouts of the pages..initially everything seemed to be proper..but currently..those pages r not opening properly in IE..(i tried in both IE 6 and IE 7)..
although it's working perfectly fine in firefox..
The problem is tht..the page takes tooo long to open (offline content in IE..frm local machine..!!..which is instantenous in case of firefox)
I suspect some problem with the javascripts used in code might be causing the problems..but am not able to figure out the problem..(This is the description of the javascript which i suspect is giving me problems...
TransMenu
* March, 2003
* Customizable multi-level animated DHTML menus with transparency.
* Copyright 2003-2004, Aaron Boodman (www.youngpup.net)
* Modified by Sean White to work with swMenuPro (http://www.google.com)
If anyone has any idea regarding such a problem pls lemme know..
mihir2608 is offline
Old 20-03-2008, 07:23 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Problems in IE
Are you loading the javascript from external site?
गीक होना माँगता
victor_rambo is offline
Old 20-03-2008, 08:33 PM   #3 (permalink)
mihir2608's Avatar
no..i hav the javascript saved on the local machine itself..but if tht code is trying to access some external site then i dunno..but i dun think this is the problem coz then even firefox should hav been unable to load tht script..
Post ur mobile internet queries, problems n problems here sourishzzz1234 Buying Advice 2 19-01-2008 07:34 PM
Cut Problems ComputerUser Software Q&A 2 11-06-2007 07:09 PM
Many Problems ark_alok Software Q&A 10 27-02-2007 06:36 PM
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
PROBLEMS!!! Arthas Software Q&A 4 14-03-2006 07:13 PM
