Old 12-03-2008, 12:58 PM   #1 (permalink)
Exclamation inserting data from SQL Server using C# in ASP.NET
We have to insert data into Sql server from the form of Asp.net using C Sharp.can neone help me in this respect !!! I need the code basically..
garv84 is offline
Old 14-03-2008, 03:07 AM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: inserting data from SQL Server using C# in ASP.NET
Whats the problem dude? Forllow these steps :-
1. Create a web for with required fields as textboxes or whatever and a button to submit it.
For Example :
<%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title>Untitled Page</title>
</head>
<body>
    <form id="form1" runat="server">
    <div>
    <asp:Panel runat ="server" ID="panel1">
    <asp:label ID="label1" runat="server" Font-Size="XX-Large">Data Entry Form</asp:label><br /><br />
        Sno : <asp:TextBox ID="TextBox1" runat="server"></asp:TextBox><br /><br />
        Name : <asp:TextBox ID="TextBox2" runat="server"></asp:TextBox><br /><br />
        Age : <asp:TextBox ID="TextBox3" runat="server"></asp:TextBox><br /><br />
        Salary<asp:TextBox ID="TextBox4" runat="server"></asp:TextBox><br /><br />
        <asp:Button ID="Button1" runat="server" Text="Insert Record" />
     </asp:Panel>
        </div>
    </form>
</body>
</html>
2. in the code behind, insert a using System.Data.SqlClient; statement.
Following is a generic code for inserting data:
protected void Button1_Click(object sender, EventArgs e)
        SqlDataAdapter da = new SqlDataAdapter("Select * from Emp", "Server=sumitslaptop\\sqlexpress; database=Practice; integrated security=true;");
        SqlCommandBuilder cb = new SqlCommandBuilder(da);
        DataSet ds = new DataSet();
        da.FillSchema(ds, SchemaType.Source);
        DataRow dr = ds.Tables[0].NewRow();
        dr[0] = int.Parse(TextBox1.Text);
        dr[1] = TextBox2.Text;
        dr[2] = int.Parse(TextBox3.Text);
        dr[3] = double.Parse(TextBox4.Text);
        ds.Tables[0].Rows.Add(dr);
        try
            da.Update(ds);
        catch (Exception ex)
            Response.Write(ex.Message);
            return;
        Response.Write("Record Added.");
Remember to change the connection string according to your computer. Also the code will vary according to the database schema. The given code is designed for following table :
create table Emp
Sno int,
Name varchar(50),
Age int,
Salary money
And do refer to your books dude, its very basic stuff. If you need one, i'll recommend
Apress Pro ASP.NET 2.0 with C# 2005
for ASP.NET 2.0.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 15-03-2008, 09:15 PM   #3 (permalink)
thanx a lot bro..will definitely try it out..thanxx again..
garv84 is offline
Old 16-03-2008, 02:45 AM   #4 (permalink)
No problemo
example of Inserting and Retrieving data from xml file hanusoft Software Q&A 1 26-09-2007 04:54 PM
Knowing Who changed data in MS SQL SERVEr rajesh_nk22 Software Q&A 1 30-06-2006 12:00 PM
Possible avoiding inserting CD evertime? a_medico QnA (read only) 3 04-10-2005 03:32 PM
Help me regarding inserting images to posts .. ayush456 QnA (read only) 3 22-12-2004 12:29 PM
