Old 05-03-2008, 10:19 PM   #1 (permalink)
Default need help in C ( using for loop without condition in bracket )
Hi friends i want to ask one question . this is realy crazy question but still i am asking
can we use for loop without giving any condition in bracket
i mean for() nothing in bracket .
frogonfloor is offline
Old 05-03-2008, 10:34 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: need help in C
Nope.. U can use it without any conditions but like this
for(;
it ll be an infinite loop
Pathik is offline
Old 05-03-2008, 10:42 PM   #3 (permalink)
for(;
It is giving syntax error . no matter it is infinite loop but it should run .
Old 05-03-2008, 11:15 PM   #4 (permalink)
Google Bot
Pathik's Avatar
damn the smiley.. use
for(;;){}
Pathik is offline
Old 06-03-2008, 12:15 PM   #5 (permalink)
The Frozen Nova
casanova's Avatar
Or while (1)
www.nerdweed.blogspot.com
casanova is offline
Old 06-03-2008, 12:52 PM   #6 (permalink)
Console Junkie
aditya.shevade's Avatar
why do you want it though?
The best way to create an infinite loop is,
while(TRUE)
--- Console Junkie
aditya.shevade is offline
Old 06-03-2008, 05:45 PM   #7 (permalink)
18 Till I Die............
Originally Posted by casanova View Post
Or while (1)
while(TRUE)
Don't both mean the same?
http://www.bash.org/?258908
mehulved is offline
Old 06-03-2008, 06:11 PM   #8 (permalink)
for(;
lol
Faun is online now
Old 06-03-2008, 07:07 PM   #9 (permalink)
Console Junkie
Yeah they mean the same.... I just use TRUE and FALSE because it is easier to understand than while 1 or 0. Theoretically, you can use any non zero positive integer to indicate TRUE.
--- Console Junkie
Old 06-03-2008, 08:53 PM   #10 (permalink)
friends i said there should not be any condition in bracket and it should run . no matter what the output is . but i think
for(;{}
is right
Old 06-03-2008, 10:34 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
What do you mean you think? Why don't you try it first before asking? Or was this a test question?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-03-2008, 10:37 PM   #12 (permalink)
i tried this one and thanks to Pathik and others for helping .
does one one know how to Obfuscate c code
Old 06-03-2008, 11:15 PM   #13 (permalink)
Commander in Chief
I guess doing a near-proper disassembly of the code should give you enough obfuscation?
Or... I might just be repeating a heard bluff here.
Harsh J
www.harshj.com
Old 07-03-2008, 07:25 AM   #14 (permalink)
can u explain it a bit more
Old 07-03-2008, 11:01 AM   #15 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
for(;;)
Any part of the for statement can be left out . However the semicolons must be used in any case. The above gives you an infinite loop cause there is no condition being tested for , no variable being initialized as a counter in it or incrementing / decrementing the counter in it. Unless you know what you were doing you would not use this syntax in one of your programs.
FilledVoid is offline
Old 07-03-2008, 09:01 PM   #16 (permalink)
thanks for explaning .
can u tell me how to Obfuscate c code
