OK, converted from one of my earlier c program
btw, prime checking can be done upto square root, which will require a little more work.
#!/bin/sh
i=2
rem=1
echo -e "Enter a number: \c"
read num
if [ $num -lt 2 ]; then
echo -e "$num is not prime\n"
exit 0
fi
while [ $i -le `expr $num / 2` -a $rem -ne 0 ]; do
rem=`expr $num % $i`
i=`expr $i + 1`
done
if [ $rem -ne 0 ]; then
echo -e "$num is prime\n"
else
fi
