Old 19-02-2008, 01:48 PM   #1 (permalink)
clmlbx's Avatar
Default how to make the string function ?
hello ,
I KNOW what is string.h and all it's function........(strrev,strcpy,strlen.and all )but how to make their own defined functions...how to pass the value to programme ..................[THAT SELF MADE FUNCTION.........THAT WE DEFINE BEFORE MAIN() FUNCTION.]
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 20-02-2008, 10:05 AM   #2 (permalink)
Default Re: how to make the string function ?
#include<stdio.h>
#include<conio.h>
int strlent(char *a)
int i;
for(i=0;a[i]!='\0';i++);
return i;
void main()
char a[100];
clrscr();
printf("\n\n\t\tEnter the string = ");
fflush(stdin);
gets(a);
printf("\n\n\t\t The length of the string is = %d",strlent(a));
getch();
The above is the function for computing string length. Try next two by yourself. Keep asking...
Always try to do better than the best.......
manubatham20 is offline
Old 20-02-2008, 12:55 PM   #3 (permalink)
alternatively and more advantageously, you can also construct your own custom header file with definitions and declarations in a C file and include that header file. (not for already built in functions like these, but other functions like say, computing integration or differential equations solution or bessel functions or as in ur case, custom string operations that doesn't exist in the package)
legolas is offline
Old 25-02-2008, 09:43 PM   #4 (permalink)
clmlbx's Avatar
@manubatham20
thanx for it, really sorry for late reply but was very busy............in that (strlent function) numeric value was returned from function how to pass a string from function.....means make a function to get reverse string (strrev)......
can anyone help me ?
I have a problem in that only how to return a value ,means in that u return value of I and printout 'a'................so how it happened.........
how to extract the needed part from a string in vb.net *GandaBerunda* Programming 3 05-11-2007 01:05 PM
PC function citizen Software Q&A 5 09-12-2006 11:55 PM
Help with the IF Function in Excel h1ghn3zz Software Q&A 3 22-08-2006 09:36 AM
cant declare a string variable... geekgod Open Source 13 12-08-2006 06:09 AM
asp 'replace' string query! 144 QnA (read only) 1 30-06-2006 10:35 AM
