Old 16-02-2008, 09:34 PM   #1 (permalink)
Default help for java
hi ! I am using jdk 1.5 but I am not able to execute any of the program. Program gets compiled but when I try to run the program it gives :
Exception in thread "main" java.lang.NoClassDefFoundError: First
I also tried j2sdk1.4.1_01 but the problem remains the same.
peyoush_thakur is offline
Old 16-02-2008, 09:40 PM   #2 (permalink)
Mad and Furious
redhat's Avatar
Default Re: help for java
The following information may be usefull :
Popular Error Encountered: Some times you may encounter
an error during the execution of program.
Exception in thread “main” java.lang.NoClassDefFoundError:
filename
Solution
Go to control panel -> System -> Click on Advanced Tab then
on “Environments Variables”
Double click on classpath and specify this path —
.;c:\Progra~1\Java\jdk1.5.0\jre\lib\rt.jar;c:\prog ra~1\Java\jdk1
.5.0\lib\dt.jar
This is taken from Nitish Upreti's Book for Beginners.
Maybe It can help you...
redhat is offline
Old 16-02-2008, 09:48 PM   #3 (permalink)
Google Bot
Pathik's Avatar
This error most commonly occurs when you try to run the compiled program using
java file.class
or
java file.class
Or if there was an error while compiling.
If it compiled correctly use
java file
Pathik is offline
Old 16-02-2008, 11:56 PM   #4 (permalink)
that cant be cuz he is able to javac
post the code here.
Faun is online now
Old 17-02-2008, 11:42 AM   #5 (permalink)
ruturaj3's Avatar
May be in ur code ur class name is Sample,
And u hv save the file with sample.java.
In java, class name & file name must be same(case sensitive).
ruturaj3 is offline
Old 17-02-2008, 01:35 PM   #6 (permalink)
Mad and Furious
redhat's Avatar
post the code here.
Yes, You maybe be able to compile, but the class wont execute.
Has'nt it been said, "during execution"??
This does work, thanks to nitish_mythology (on this forum)
redhat is offline
Java programming..how can I distribute java program....? Manojap Programming 5 16-05-2009 02:46 PM
c++, java and more mak1012 Open Source 11 10-08-2006 03:47 PM
JAVA or C..need help Alexander_H QnA (read only) 21 02-02-2005 02:41 AM
