Old 09-02-2008, 12:50 PM   #1 (permalink)
Default plz help me
hi friends
one of my friend need menu driven program in 'C' the output may be like this
file edit
new cut
open copy
edit paste
save exit
save as
quit
exit
plz help him
Ravi.Y
yrakesh78 is offline
Old 09-02-2008, 01:50 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: plz help me
Is your friend shy that he cannot post here himself?
गीक होना माँगता
victor_rambo is offline
Old 11-02-2008, 11:19 AM   #3 (permalink)
hmmm...menu driven programming in C....i donno whether we can design any 'windows' or 'menu graphics' in C as such...perhaps u should go for CPP...It has support libraries for menus...Suppose u want to go for C only..then u can use a switch rite!!
while(1)
///show all options
////ask to enter choice like
int choice;
scanf("%d",&choice);
switch(choice)
///for each choice call a function
guess this helps...cheers
Jove is offline
Old 12-02-2008, 03:48 AM   #4 (permalink)
18 Till I Die............
I believe it can be done using loops and gotoxy, within cmd prompt but that would look really bad IMO. TC will have some options in it's graphics library but that will make the program non-portable and non-standard.
http://www.bash.org/?258908
mehulved is offline
Old 12-02-2008, 03:55 AM   #5 (permalink)
Rockstar11's Avatar
Talking Re: plz help me
lolzz
Zindagi Toofani Hai... Jahan Hai DuckBurg!
Rockstar11 is offline
