Old 30-01-2008, 09:45 PM   #1 (permalink)
Default help!
I am trying to self learn c++ and the first program mentioned in my book is
#include <iostream>
using namespace std;
int main()
cout << "c++ is better than c.\n ";
return 0;
In which of the digit's cd/dvd, the program which can execute this code is given?
saubrl is offline
Old 30-01-2008, 09:58 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: help!
^^what you need is a compiler.If you are on linux then g++ is preinstalled anf you can use it through terminal.In windows you need to download and install a compiler(most comes as IDEs,IDE:integrated develpoment environment,its just a compiler+a good editor in simple terms).I would suggest devc++.
I dont know about digit's cd\dvd having compilers.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 30-01-2008, 10:24 PM   #3 (permalink)
Default Re: help!
I have a very slow connection and takes over an hour. So anything from digit's?
saubrl is offline
Old 30-01-2008, 10:29 PM   #4 (permalink)
damn busy...
utsav's Avatar
Default Re: help!
Try turbo c++ to compile.its ok for learning c++ and also a small download
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 30-01-2008, 10:57 PM   #5 (permalink)
Default Re: help!
devc++ is 13.5mb,so it will take sometime on your slow connection but I assure you it will be worth it.
@utsav:turbo c++?you gotta be kidding me.
Old 31-01-2008, 07:41 AM   #6 (permalink)
Default Re: help!
Unless you are going to a class where they are teaching with Turbo C++, I would recommend that you avoid Turbo C++ because it has a lot of non-standard functions... You will end up creating programs that will not work easily with others...
Dev C++ is a very good alternative for learning... It has a simple interface that will help you get started...
Arun
sakumar79 is offline
Old 31-01-2008, 09:11 AM   #7 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Default Re: help!
@saubrl
Download Dev C++
Do u hv any e-book regarding c++?....
||uLtiMaTE WinNER||
Ron is offline
Old 31-01-2008, 01:07 PM   #8 (permalink)
damn busy...
utsav's Avatar
Default Re: help!
I use turbo c++ for only my school programming only.only one more month i hav 2 use it
www.techjunkiez.com
utsav is offline
Old 31-01-2008, 09:49 PM   #9 (permalink)
SivaChand
Default Re: help!
Read books and execute programs... I used turbo c++
Always look at what you have left.Never look at what you have lost
kpmsivachand is offline
