Old 28-01-2008, 05:45 PM   #1 (permalink)
~[::BOoYaKa::]~
Default PHP Help Needed...
My site use PHP as scripting language... I created a simple search menu to fetch results from the database, and display the results...
It works fine and results are displayed as per the need of the user...
But the problem is that it displays all of the found results on a single page, i want to display 10 results per page, if there are more than 10 results it should automatically create next page link at the bottom...
I am unable to solve this problem... If there are many results, like 100, all of them are displayed on same page and it looks like a mess......
Please can someone help...
Thanx..
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 28-01-2008, 06:11 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: PHP Help Needed...
Use embedded URL to get LIMIT of query.
eg: http://domain.com/search.php?query=STRING&startfrom=11&upto=20
Use IF operator to see if LIMIt varibales are null. If NULL set to 1 and 10.
And for making the embedded URL use loops and manipulate incrementer mathematically.
गीक होना माँगता
victor_rambo is offline
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Q&A 3 21-11-2007 12:26 PM
Help Needed Dragoniteid2 QnA (read only) 1 19-07-2006 07:29 AM
needed 2 buy a good camera????? help needed.. The Day Walker! Cameras and camcorders 5 02-07-2005 04:43 PM
