Old 27-01-2008, 12:46 PM   #1 (permalink)
The Unknown's Avatar
Default Python: How to check integer ?
Hi I am new to Python.
Suppose an app is accepting input then how do I validate that it is integer or not ?
KDE on ArchLinux
The Unknown is offline
Old 27-01-2008, 01:16 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Python: How to check integer ?
Use a simple try and catch block?
a = raw_input('Enter an integer: ')
try:
	a=int(a)
except:
	print 'Please enter a valid integer'
	exit(1)
print 'You entered:', a
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-01-2008, 01:56 PM   #3 (permalink)
Thanks. Well, my usage isn't command line but using mod_python & httpd. I need this for my new upcoming site which is going to be programmed in Python.
KDE on ArchLinux
Old 27-01-2008, 04:29 PM   #4 (permalink)
Commander in Chief
Well, basically all I'd said was to try an int() conversion and except its error messages in case it encounters a number/literal not suitable for conversion to base 10. That is how you check for an input being a valid integer convertible.
This method is not "command-line", only my test input was. Learn some more Python before jumping into the line of fire.
Harsh J
www.harshj.com
Python tutorial (this is a request) karmanya Programming 4 27-05-2007 05:48 AM
Python Programming The Unknown Programming 15 21-04-2007 09:57 PM
best site to learn python language knoahshyam Tutorials 2 19-02-2006 02:21 PM
Python Unplugged .. !! shrek_incredible Open Source 1 14-11-2004 12:09 PM
