Old 24-01-2008, 03:25 PM   #1 (permalink)
Red face Method faster than quick sort in C
Is there any alternate methode exist which is faster than quick sort to sort the arrays in C language. Please tell the source if you have.
manubatham20 is offline
Old 24-01-2008, 05:11 PM   #2 (permalink)
Default Re: Method faster than quick sort in C
dun remember but one among the following is quicker and excels at worst case time complexity.
insertion sort or selection sort
Faun is online now
Old 24-01-2008, 06:11 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes but it also depends on the amount of data it needs to sort. For small data insertion or selection sorts are good and if we apply this to the recursing quick sort or merge sort when it has sorted somewhere through the middle of its pieces, the overall efficiency rises, since quick sort gets slower for smaller data compared to other methods.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-01-2008, 05:30 PM   #4 (permalink)
Go for B tree sort. Do a simple Google search to find the code in C
Sudhir Mangla
http://DevelopersVoice.com
(VC++ FAQ, MFC FAQ, C++ FAQ)
http://Programmerworld.net
(Free books and source code)
sudhir_mangla is offline
Sort it out chitra_654 Mobiles and Tablets 12 06-02-2008 02:03 PM
sort +r ?? ravix Open Source 1 07-07-2006 08:30 PM
