Old 20-01-2008, 11:49 AM   #1 (permalink)
adi007's Avatar
Question how to add a hotkey in VB
Is there any way to add a hotkey to some actions in a VB..
for example in case of webshots ctrl+alt+w will change the wall paper..
is there any method to do so in VB program..
Note that i have not asked how to add shorcut key-->it's easy.
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 20-01-2008, 11:56 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: how to add a hotkey in VB
The example at the following link looks clear, however I have not tried it yet, will do so later.
http://www.vbaccelerator.com/home/VB...ys/article.asp
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-01-2008, 11:09 AM   #3 (permalink)
adi007's Avatar
it's for VB6 i presume....
i will try it but there are huge chances that it will not work in VB2008..coz there is drastic change from VB6 to present VB...
Thanks for the link
It would be helpful if someone finds the way to add hotkey in case of VB2008
adi007 is offline
add a hotkey to any app.. adi007 QnA (read only) 4 22-01-2008 04:16 PM
