Old 19-01-2008, 04:48 PM   #1 (permalink)
j1n M@tt's Avatar
Smile topics for project
Hi guys, I'm doing B.E in Computer Science and am now in 6th sem. This sem we hav to do our mini project.Can u guys here suggest some nice topics for d project. I wanna do something cool !!....plz help me
Suggest some:
  • hardware based,
  • web based, or
  • app. based projects
I prefer to do projects in d following languages:
  • 32-bit C
  • C++/VC++
  • JAVA
  • .NET
  • flex
d first 2 r ma favorites,in Java and .Net am not dat geek, and flex I don't know nothing; just started studying it.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 19-01-2008, 04:50 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: topics for project
Another one here.. reporting for double post.
Charan is offline
Old 19-01-2008, 05:09 PM   #3 (permalink)
Stay Silent!
enticer86's Avatar
Double post, reported.
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 19-01-2008, 05:12 PM   #4 (permalink)
j1n M@tt's Avatar
guys I don't know wat happened ,I posted one but two appeared.........
plz anwser ma question instead of reporting so much
j1n M@tt is offline
Old 19-01-2008, 07:13 PM   #5 (permalink)
j1n M@tt's Avatar
bump
j1n M@tt is offline
Old 19-01-2008, 07:20 PM   #6 (permalink)
dOm1naTOr's Avatar
Multithreading is only excusable in this thread:
Your Favourite Thread ??
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 19-01-2008, 07:44 PM   #7 (permalink)
j1n M@tt's Avatar
bump....
plz look up ma post and answer guys
help help....
j1n M@tt is offline
Old 19-01-2008, 08:12 PM   #8 (permalink)
MysticDews's Avatar
I did this last year as my project..
U can show controlling home devices using a cell phone. Like i had used a Nokia cell phone with bluetooth, n created a model of a house, with appliances like lights, fans, electronic curtains, oven, computer, etc. & had the cell phone send msgs to a PC.
Then, i wrote a program using vb.net 05 and kept it running on the PC. The program was such that, when a message was sent to the PC, a device in that house would start functioning.
All this was done using a parallel port cable, a bluetooth enabled phone, a bluetooth dongle on the pc, a vb.net code and some arbit stuff to show the appliances and to make the model..
________________________________________________
In love with my Mac 
MysticDews is offline
Old 19-01-2008, 08:54 PM   #9 (permalink)
j1n M@tt's Avatar
Question Re: topics for project
Do v need any external circuit for this? or can v only connect one device at a time?
And hw did u wrote the app. dat is running on d mobile ? in Java??
j1n M@tt is offline
Old 19-01-2008, 10:17 PM   #10 (permalink)
j1n M@tt's Avatar
Hey , anybody hav any other ideas ?? plz post and help....
j1n M@tt is offline
Old 19-01-2008, 10:33 PM   #11 (permalink)
SivaChand
Do you know any scripting Language?
Always look at what you have left.Never look at what you have lost
kpmsivachand is offline
Old 19-01-2008, 10:36 PM   #12 (permalink)
j1n M@tt's Avatar
If necessary I will use Javascript.....
j1n M@tt is offline
Old 19-01-2008, 10:43 PM   #13 (permalink)
SivaChand
If You know js then u can do Library project....
Old 19-01-2008, 11:01 PM   #14 (permalink)
j1n M@tt's Avatar
Wat do u mean by Library project? windows library??? If not, am not interested. Similar projects r commonly done by other students. I wanna do something different.
j1n M@tt is offline
Old 19-01-2008, 11:16 PM   #15 (permalink)
MysticDews's Avatar
Arrow Re: topics for project
The electric supply in my project was voltage from the parallel port. There are 6 (12 actually, but 6 each of Ground n their upper Voltages) pins that can give out usable voltage in a parallel port. So u can have 6 outputs. And the flow of current was controlled by the PC application.
Yeah, you need a simple external circuit, and you can easily make it yourself..
Like i had used an electric motor to represent a fan. The Back EMF problem with motors is the main reason to have that circuit and it had a set of diodes to create uni directional current flow.
There was no special application on the cell phone, it was just a 'Note' sent over the bluetooth.
Old 19-01-2008, 11:34 PM   #16 (permalink)
j1n M@tt's Avatar
Smile Re: topics for project
thanx MysticDews.
d project u said is a nice one...I will try to make some mods in ur ideas and will be considering it with ma group members.
V hav some topics like
  • Image editing online apps in flex(flex is d new emerging language from Adobe 4 web based apps).
  • Download managers like torrents
  • Hardware monitoring + tweaking apps
  • Encryption software
Wat do u guys suggest? Which one is d best? If any other cool topics, plz post it guys..........
j1n M@tt is offline
Old 19-01-2008, 11:46 PM   #17 (permalink)
MysticDews's Avatar
^ No thanks n all buddy...
U cud also consider these topics..
1. Broadband Through Power Lines,
2. Electronic Language Translation
Old 19-01-2008, 11:52 PM   #18 (permalink)
j1n M@tt's Avatar
hey man,r u insane ? or is it true dat v can sent Broadband signals thr Power lines??!!!!
Can u xplain hw?
j1n M@tt is offline
Old 20-01-2008, 04:47 PM   #19 (permalink)
j1n M@tt's Avatar
j1n M@tt is offline
Old 21-01-2008, 07:18 PM   #20 (permalink)
j1n M@tt's Avatar
bump
j1n M@tt is offline
Old 21-01-2008, 07:35 PM   #21 (permalink)
MysticDews's Avatar
Yeah, if a Wikipedia entry is assumed to be true, it is possible!
I found that last year while searching for my project
Old 05-02-2009, 09:48 AM   #22 (permalink)
Suggest some:
  • hardware based,
  • web based, or
  • 32-bit C
  • C++/VC++
  • JAVA
  • .NET
  • flex
Hi, Try this website for ideas.
http://www.csreference.net/
http://www.csreference.net/drupal/in...reprojectideas
http://www.csreference.net/drupal/in...ebprojectideas
mayurms is offline
Common Topics Covered / Frequently Discussed Topics alib_i QnA (read only) 8 22-09-2007 07:41 AM
