Old 18-01-2008, 08:07 PM   #1 (permalink)
Chetan1991's Avatar
Question Please help me in VB code
Hi Guys!
The following text is the source code of my multiplayer snakes and ladders game in VB.
I am not getting the desired result with it. Please tell me what are the errors in it.
'General Declarations
Dim C_1, C_2, C_3, C_4, C_5, C_6, C_7, C_8, C As Integer
Dim p, pcol, Last
'Decorations
Private Sub blink_Timer()
On Error Resume Next
Dim po00 As Byte
po00 = Int((Rnd * 15) + 1)
title.ForeColor = QBColor(po00)
bound1.BorderColor = QBColor(po00 + 1)
bound2.BorderColor = QBColor(po00 + 3)
End Sub
Private Sub reset_Click()
Form_Load
e(C_p).BackColor = &H80FF&
For y = 1 To 100
If y <> Cur Then e(y).BackColor = &H80000016
Next y
End Sub
Private Sub exit_Click()
End
End Sub
Private Sub Form_Load()
'obtaining the number of players from other form
Last = Val(number.num.Text)
p = "1"
C_p = 1
End Sub
Private Sub roll_Click()
Label3.Caption = Str(C_p)
'changing turns
If p = Last Then
p = 1
Else
p = p + 1
End If
'Generating a random number from 1 to 6
Randomize
C = Int((Rnd * 6) + 1)
'Displaying the number on dice
Select Case C
Case 1
dot(4).Visible = True
dot(0).Visible = False
dot(1).Visible = False
dot(2).Visible = False
dot(3).Visible = False
dot(5).Visible = False
dot(6).Visible = False
Case 2
dot(5).Visible = True
dot(2).Visible = True
dot(4).Visible = False
Case 3
Case 4
dot(0).Visible = True
dot(1).Visible = True
Case 5
Case 6
dot(3).Visible = True
dot(6).Visible = True
End Select
'Deciding winning condition
If C_p + C >= 100 Then
MsgBox (" Player " + p + "You Win!!!")
C = 0
reset_Click
End If
'Code for Snakes and ladders
If e(C_p + C).Tag = "snake" Then
MsgBox ("Caught by a snake!")
C = -1 * (Int((Rnd * 10) + C))
ElseIf e(C_p + C).Tag = "ladder" Then
MsgBox ("You got a ladder!!")
C = Int((Rnd * 10) + (C + 4))
End If
'colouring the current position
e(C_p + C).BackColor = QBColor(p)
'setting the new block as current block
C_p = C_p + C
'removing color from other blocks
For k = 1 To 100
If k <> C_p Then e(k).BackColor = &H80000016
Next k
End Sub
Chetan1991 is offline
Old 18-01-2008, 11:09 PM   #2 (permalink)
ruturaj3's Avatar
Default Re: Please help me in VB code
if u can provide entire project then i can try. only source wont work.
ruturaj3 is offline
Old 19-01-2008, 01:16 AM   #3 (permalink)
in search of myself
CadCrazy's Avatar
Digit forum is not multithreading campatible
http://www.thinkdigit.com/forum/showthread.php?p=724561
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 19-01-2008, 01:23 AM   #4 (permalink)
damn busy...
utsav's Avatar
It may have happened by mistake .i am sure abt it
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 19-01-2008, 01:58 AM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
its a double post.. I had reported one .. but it was not delete.
Charan is offline
Old 19-01-2008, 11:23 AM   #6 (permalink)
damn busy...
utsav's Avatar
Apna cadcrazy aajkal voluntary mod ban gaya hai
www.techjunkiez.com
utsav is offline
Old 19-01-2008, 07:20 PM   #7 (permalink)
dOm1naTOr's Avatar
U can do multithreading only in here:
Your Favourite Thread ??
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 20-01-2008, 01:40 PM   #8 (permalink)
Chetan1991's Avatar
I've uploaded the project. Here's the link :
http://en.uploadtornado.com/12YP0BLT5ODY/snakes'n'ladders.zip
lock code..not security code magneticme200 Mobiles and Tablets 3 29-12-2007 07:15 PM
Need a code... Ron QnA (read only) 4 17-12-2006 01:42 AM
Help with Code Mr.Cool QnA (read only) 10 09-12-2006 02:37 PM
