Old 12-01-2008, 10:53 AM   #1 (permalink)
Default Data Compression
Guys i am very interested in data compression.
is it possible to implement Huffman algo using C or Java will be a better option..?
garv84 is offline
Old 12-01-2008, 12:46 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Data Compression
Java will make it easier I think, but if its efficiency you need, C's the way to go.
I'd recommend Python or any other such new languages though. Coding Huffman on them is just a matter of few minutes!
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-01-2008, 08:58 PM   #3 (permalink)
arrrre yaaar.mujhe bol do.mere pas le lena .huffman compression and decompression using c
maitrasagnik is offline
Old 12-01-2008, 10:42 PM   #4 (permalink)
lol..
garv84 is offline
compression utility ismart Software Q&A 23 20-02-2007 10:34 AM
NTFS vs. RAR compression... QwertyManiac QnA (read only) 8 23-08-2005 06:38 PM
Data Compression and decompression piyushp_2005 QnA (read only) 4 13-04-2005 07:59 PM
Compression help vijaythefool QnA (read only) 21 20-02-2005 09:33 PM
vcd compression redhat_adi QnA (read only) 5 13-02-2005 05:54 PM
