LinkBack (4) Thread Tools Display Modes
Old 06-01-2008, 05:32 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Web Junky 2.0
debiprasad_sahoo's Avatar
Exclamation How to Copy to Clipboard in Firefox and other browsers other than IE?
Dear friends, I need to copy some contents to clipboard on the click event of a button. For IE the js code is as follow
window.clipboardData.setData('Text', 'the text you need to copy');
For firefox there is some complex code, which can copy to clipboard, but it is not working correctly. It shows this error
uncaught exception: A script from "http://loveorkut.com/" was denied UniversalXPConnect Privilages.
The js code is as follow
        netscape.security.PrivilegeManager.enablePrivilege('UniversalXPConnect');
        var clip = Components.classes['@mozilla.org/widget/clipboard;1']
                     .createInstance(Components.interfaces.nsIClipboard);
        if (!clip) return;
        var trans = Components.classes['@mozilla.org/widget/transferable;1']
                  .createInstance(Components.interfaces.nsITransferable);
        if (!trans) return;
        trans.addDataFlavor('text/unicode');
        var str = new Object();
        var len = new Object();
        var str = Components.classes["@mozilla.org/supports-string;1"]
                    .createInstance(Components.interfaces.nsISupportsString);
        var copytext = "The Text you want to copy";
        str.data = copytext;
        trans.setTransferData("text/unicode", str, copytext.length*2);
        var clipid=Components.interfaces.nsIClipboard;
        if (!clip) return false;
        clip.setData(trans, null, clipid.kGlobalClipboard);
However this code works in local, it asks for a confirmation only to give access to the clipboard. I need this to be worked in Internet also. Any other good code will be better. Please help.
If you have any questions or ideas, then please discuss here.
More reason to love orkut
Get Scraps, Testimonials and many more...
debiprasad_sahoo is offline
Old 07-01-2008, 08:19 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: How to Copy to Clipboard in Firefox and other browsers other than IE?
Mozilla doesn't allow copying to clipboard unless the script is signed (Digital signatures, from Verizon, etc.). And even if its signed it asks for user permission before allowing the script to do so.
But there is one hack, it uses a flash object to perform the same task and doesn't require permissions, etc. You may use it from here: http://www.jeffothy.com/weblog/clipboard-copy/
(P.s. There is a setting in About:Config which allows script to copy to clipboard, but it makes no sense asking a user to change all those defaults, etc.)
Or go the Mozilla's ugly and long way: http://developer.mozilla.org/en/docs..._the_Clipboard
Harsh J
www.harshj.com
QwertyManiac is offline
Old 07-01-2008, 08:48 AM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
There is this flash component which allows copying to clipboard from any browsers. Its not designed by me. But I had used it once and its working in almost all browsers I have tested. I am not getting the exact source of this file. But its released under the GPL, so freely distributable.
Download this file: http://rapidshare.com/files/81866988...board.swf.html
Keep it in the same folder.
Here is the code:
<script type="text/javascript">
function copy(text2copy) {
  if (window.clipboardData) {
    window.clipboardData.setData("Text",text2copy);
  } else {
    var flashcopier = 'flashcopier';
    if(!document.getElementById(flashcopier)) {
      var divholder = document.createElement('div');
      divholder.id = flashcopier;
      document.body.appendChild(divholder);
    document.getElementById(flashcopier).innerHTML = '';
    var divinfo = '<embed src="_clipboard.swf" FlashVars="clipboard='+escape(text2copy)+'" width="0" height="0" type="application/x-shockwave-flash"></embed>';
    document.getElementById(flashcopier).innerHTML = divinfo;
</script>
Now pass any parameters to the function copy(parameters) and it will be copied to the clipboard instantly.
Like this:
<input type="button" onClick="copy('ThinkDigit Forum')">
This will copy Thinkdigit Forum to the Clipboard.
Tell me if you have any problems.
Nokia N86 8MP
Lucky_star is offline
Old 07-01-2008, 09:53 AM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
^ yup.. it must work !
Gigacore is offline
Old 26-01-2008, 01:32 PM   #5 (permalink)
Web Junky 2.0
I was bit busy. That's is why I can not test it. Today I tested it. It works fine in IE, Firefox and Opera. Thank you.
LinkBack to this Thread: http://www.thinkdigit.com/forum/programming/77544-how-copy-clipboard-firefox-other-browsers-other-than-ie.html
??js??firefox?????? - Firefox ??? - ?? @ Mozest.com - Mozilla ?? This thread Refback 29-03-2012 12:18 PM
添加js代码firefox无法复制内容 - Firefox 桌面版 4.0.* - 广场 @ Mozest.com - Mozilla 中文支持社区与中文本地化网站 This thread Refback 09-04-2011 02:29 PM
添加js代码firefox无法复制内容 - Firefox 4.0.* - 广场 @ Mozest.com - Mozilla 中文支持社区与中文本地化网站 This thread Refback 30-03-2011 05:43 PM
添加js代码firefox无法复制内容 - Firefox 4 专区 - 广场 @ Mozest.com - Mozilla 中文支持社区与中文本地化网站 This thread Refback 30-03-2011 10:29 AM
Now ... u can protect ur clipboard theft in IE7. anandk Tutorials 2 23-12-2006 05:58 PM
Windows Clipboard s18000rpm Software Q&A 4 28-08-2006 02:49 PM
Browsers, Firefox: Make firefox 10x faster, 100% working saipothuri Software Q&A 2 13-08-2006 11:33 AM
Clipboard Pragadheesh QnA (read only) 3 11-08-2006 08:46 PM
