Old 21-12-2007, 01:57 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default urgent help required.please solve this program.
using constructor write a program in c++ to generate first n terms of fibonacci series.
(you can take n=5)
how to do it using constructor.
please help.
quan chi is offline
Old 21-12-2007, 02:27 PM   #2 (permalink)
Default Re: urgent help required.please solve this program.
lol..its easy man
just write the whole code in the constructor passing n as an argument.
try it now, probably someone will come up with complete code.
Faun is online now
Old 27-12-2007, 08:08 PM   #3 (permalink)
Mad and Furious
redhat's Avatar
Smile Re: urgent help required.please solve this program.
Suppose this is some sort of "SCHOOL" Homework!!!
Jus create a parameterized Constructor n accept the value of 'n' within it
Simple!!!!!
redhat is offline
Old 30-12-2007, 04:01 AM   #4 (permalink)
search on google u can do it
and here no one is free to do ur homework
so have some tricky questions
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 30-12-2007, 08:44 AM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
I've not compiled this code and even not programmed C++ for a long time.
Please check this.
The program will be something like -
 include <iostream>
class factorial
    long int fact=1;
    factorial (int no)    // This is a constructor with 1 argument
        int store=no;
        for ( ; no <1 ; --no)
            fact*=no;
        cout << "Factorial of " << store << "is " << fact;
int main()
    int no;
    factorial f1(3);    // Direct call
    // User choice
    cout << "Enter a number : ";
      cin >> no;
    factorial f(no);
    return 0;
Sorry, if there are mistakes.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 30-12-2007, 11:45 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
As others said, use a default constructor and a parameterized constructor to call some function which outputs the needed.
#include<iostream>
using namespace std;
class A
    int n;
    public:
        void call(int n)
            cout<<"\nFibonacci numbers upto "<<n<<" are: \n";
            int a(1),b(1),t(0);
            for(int i=0;i<n;i++)
                cout<<a<<" ";
                t=b;
                b=a+b;
                a=t;
            cout<<endl;
        A()
            cout<<"\nEnter the number of Fibonacci numbers you wish to calculate: ";
            cin>>n;
            call(n);
        A(int n)
            call(n);
int main()
    A *a;
    cout<<"\nDefault constructor call (Asks for user input):\n";
    a =  new A;
    cout<<"\nParameterized constructor call (Assumes input as value passed):\n";
    a = new A(10);
    return 0;
Outputs as:
Enter the number of Fibonacci numbers you wish to calculate: 6
Fibonacci numbers upto 6 are:
1 1 2 3 5 8
Fibonacci numbers upto 10 are:
1 1 2 3 5 8 13 21 34 55
Harsh J
www.harshj.com
QwertyManiac is offline
(Urgent!!) Need A Software Or Program For Ma' Office!!! harry_nitish Software Q&A 3 17-07-2007 06:05 PM
Urgent Help Needed 2 Solve Win Xp Problem SLIPKNOT Software Q&A 7 17-11-2006 12:22 PM
solve the problem ofasus mother board (URGENTLY REQUIRED) Tuku Hardware Q&A 3 17-09-2006 10:10 PM
Urgent Help required!!! sourabh_nandi QnA (read only) 3 22-07-2005 11:39 PM
